Did you press the open button on the FOB twice, before opening the door and leaving the car?
Things you only discover after a long time with your car..
- RobbiZ4
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
OnlineMarcoose
For the life of me, I cannot remember or find how to toggle between day and night. Could somebody please help? Thanks.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
OnlineMarcoose
- N4LLY
What an idiot i am Double click and physicaly open door and window shoots down, close door and up it goes
Is there a way to turn this off? (Without iDrive) Only noticed it when I got a smarttop module, when I triple unlock to put the roof down it must trigger the comfort entry as the window goes back up when I close the door. If I've got the roof down I want the windows to stay down
Had a look through carrista and couldn't find anything relating to it, possible the smarttop itself is triggering it but can't find any options for that in its settings.
- ronk
It’s a while since I did this but I seen to remember changing the setting to Night mode - pressing and holding button 8
From map view select 8 and it swaps between night and day mode.
If it won’t toggle between you could use 7 for Day and 8 for Night
You only need the one button to toggle between night n dayronk wrote: ↑Sat Jul 17, 2021 2:13 pmIt’s a while since I did this but I seen to remember changing the setting to Night mode - pressing and holding button 8
OnlineMarcoose
Ok. More basic. How do we toggle from day to night modes? Thanks.
- ronk
The button set to night - press again and it sets the screen to day! Ie it toggles between the two modes
OnlineMarcoose
Sorry, Ron. I’m still drunk from celebrating the EUFA championship.
Which button makes the toggle? Thanks.
- ronk
Set the system to Night mode
Press and hold Button 8
Now set a destination and start navigation
Tap button 8 and if shows daytime view
Tap button 8 and if shows night view
[/quote]
This is mentioned in the smart top manual. You need to switch comfort access off using Carly, not sure if other devices can also do it. Worked on mine.
[/quote]
- ronk
Originally I had 8 for night mode and 7 for day - but by chance I realised pressing 8 it swapped between the two modes.
OnlineMarcoose
Ok. It took sniffing around the iDrive, but I’ve found and assigned #6 to toggle between day and night modes. (Me car only has 6 buttons.) During bright days (like today in SF) I find the display useless whether in day or night mode. I have to wait for a shaded patch or the evening to read to bloody thing. Thanks for all the good tips.
- ronk
You’ve set a doubt In my mind now - has mine got 6 or 8?
I’m going to check tomorrow.
