Things you only discover after a long time with your car..
Kiwi_Mike
Post by Kiwi_Mike » Sun Jul 18, 2021 5:04 am
ronk wrote: Sat Jul 17, 2021 11:24 pm You’ve set a doubt In my mind now - has mine got 6 or 8?
I’m going to check tomorrow.
From memory in mine it’s 6 numbered buttons then the trf (traffic) and Mode = 8. All can be programmed to any task (I’m away skiing at present and car is at home so can’t check).
Swampy1982
Post by Swampy1982 » Sun Jul 18, 2021 8:17 am
Stash36 wrote: Thu Jul 08, 2021 11:17 am If you have idrive, the 8 buttons can be assigned to any function and can differ for each key. I use
1. Aux audio for my firefly usb thing
2. FM radio
3. FM radio
4. Close the screen
5. AM 5 live
6. Call the missus (call me on her key)
7. Cancel navigation
8. Navigate to holiday home
On my f30, took me 18 months to discover if you touch (not press) the button it displays what it does on the screen
alex7123
Post by alex7123 » Sun Jul 18, 2021 9:16 pm
Stash36 wrote: Sat Jul 17, 2021 10:56 pm Is there a way to turn this off? (Without iDrive) Only noticed it when I got a smarttop module, when I triple unlock to put the roof down it must trigger the comfort entry as the window goes back up when I close the door. If I've got the roof down I want the windows to stay down :D
Had a look through carrista and couldn't find anything relating to it, possible the smarttop itself is triggering it but can't find any options for that in its settings.
This is mentioned in the smart top manual. You need to switch comfort access off using Carly, not sure if other devices can also do it. Worked on mine.
[/quote]
Ah brilliant thanks, I'll have another look on carrista, otherwise hope my mate still has his Carly subscription!
