CHANGE OF RUNFLATS TO NON RUNFLATS
When to check tyre pressure when atmospheric pressure is high or low?
- enuff_zed
Oh that would depend on the coefficient of friction of the road you're going to use.
- sars
When the conditions are ambient silly
hectoPascals, brilliant, where did you drag that one up from
and you’ve have unwittingly done one of my pet hates in my industry, standard convention is the bar, psi or if you want to be proper it’s the MPa (or if you are a real gimp kg/cm2) however calculating anything with pressure in the equation it is always absolute. So my pet hate is peeps writing barg or psig to indicate that it’s gauge pressure, duh all measured pressure is gauge so it’s just bar or psi or Pa, if it’s atmospheric the SI convention is to state the units as bar (abs) thus: - it is 1013 hecto Pascals (abs)
Gorgeous SFR Z4 M40i
Gone 2017 Iridium SL400, 2015 435d xDrive Convertible, 2012 E350 CDi Convertible, 2010 DSB Z4 sdrive30i, 2008 Audi A4 Cabriolet, 2006 Phoenix Yellow Z4 2.5Si, 2003 Saab 9-3 Convertible
OnlineArgyll Andy
Sars, if I put that int Google translate is there any chance I’ll understand it any bettersars wrote: ↑Fri Jul 02, 2021 7:44 pmWhen the conditions are ambient silly
You changed the colour order for your G29 yet?
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
- sars
No it’s still red my last BMW was blue and I really wanted something different and I haven’t had a red convertible since my 74 MGB Roadster
SARS…for the International Civil Aviation Organisation (ICAO). The reference point for all pressure settings is hecto pascals …shortened to hPA previously it was milli bars..or inches (of mercury) in USA
You can have a standard reference 1013 which is what you set your altimeter to when flying flight levels..eg FL230 or
If you want to be able to land when your altimeter shows zero then you set QNH which is pressure adjusted to your point on the earth at this exact point in time or you can have QNH which is pressure altitude set so that sea level (average) would read zero on your altimeter (if you landed on the sea)
When we move back to tire pressures we should in aviation correct back to ISA..ie a pressure of 1013 hecto pascals and a temperature of 15c
Any variation in pressure or temp should then be subject to a correction factor based on the physical characteristics of the object in question
See this as a working example…. https://publicapps.caa.co.uk/docs/33/Sa ... 014004.pdf
- sars
So all that copying and pasting to tell me it’s used in the in aviation industry
- sars
So in your industry, that is aviation, all pressures are atmospheric, excepting the ones you have in your tyres
- N4LLY
The original question was (IIRC) whether tyre pressures should be adjusted for non-RF tyres over the recommended for RFTs.
The answer is NO.
Then a forum member proceeded to try to stamp their authority over all things technical relating to the E89 and thus ensued a discussion which no-one cares about. Said member was then brought to task by people with more knowledge but refused to surrender to superior knowledge and dug themselves a bigger hole. That's how I see it anyway
Even though the said member is in charge of airworthiness of all aircraft in the whole world; which is a bit of a worry
PS no offence intended or inferred, it's all in good humour
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
Seems to happen regularly with this technical god I'm afraid.
2012 Z4 2.0 M-Sport Atacama Yellow
2000 Z3 3.0
2016 Vauxhall GTC Sunny Melon Yellow
2000 Jaguar X308 Sovereign 4.0
1969 Jensen Interceptor 6.3 litre
2000 Z3 3.0
