CHANGE OF RUNFLATS TO NON RUNFLATS
Just changed the 4 Bridgestone Potenza run flat tyres on my 2016 E89 Z4 to 4 Michelin Primacy non
runflats.
The technician was not sure of the tyre pressures but put 36 in each wheel (car has 17 inch alloys)
Can anyone advise me of the correct pressures to use
Thank you
runflats.
Thank you
Hi there,
made a similar change some years ago on my E85 using the same pressure as before, 2,3 bar front and rear.
Enjoy the difference in tyres!
- enuff_zed
Firstly, I would double check the pressures as in my experience the fitters don't always get it quite right.jaydon9269 wrote: ↑Wed Jun 30, 2021 1:55 pm Just changed the 4 Bridgestone Potenza run flat tyres on my 2016 E89 Z4 to 4 Michelin Primacy non
runflats.
Thank you
Then you may find you have to experiment a little to find what suits you best but you don't have a bad starting point there.
Mine are 18" wheels, but I ended up with 34F & 36R. Others have found slight differences to that suit them better.
It does come down to driving style and how it feels through the seat of your pants too.
I would also suspect different tyres react to different pressures too.
In short, keep tweaking until you're happy.
- sars
It really depends, let’s assume you have a square set up, that is 225/45 R17 all round so the pressures are the same front and rear. I would suggest you drive it for a while and alter them as necessary. There’s a mixed consensus on here some have dropped the pressure, I myself increased them by a few psi but that is possibly because I ran winter tyre on the 17” wheels and bought a set of 18” wheels for summer.
Gorgeous SFR Z4 M40i
Gone 2017 Iridium SL400, 2015 435d xDrive Convertible, 2012 E350 CDi Convertible, 2010 DSB Z4 sdrive30i, 2008 Audi A4 Cabriolet, 2006 Phoenix Yellow Z4 2.5Si, 2003 Saab 9-3 Convertible
I changed from RFTs to gooduear Assy 5 - fitter used the same tyre pressures as the RFT - i think im now on 32 front and 34 rear
Here’s a table from Continental with suggested tyre pressures for various sizes..
I found their 18” asymmetric tyre pressures too high especially the rears..
Their 17” tyre pressures seem better but still a bit high ..
The main reason for the high pressures is the fact that if you insist on sustaining 155 mph you need a lot of tyre pressure..
I’ve yet to find any tyre manufacturer offering any specific adjustments for run flat vs non run flat tyres…
As others suggest starting at the 32/34 to 36/38 works for many,,
- 2A9205E4-52BA-4848-9188-C54478C54EBA.png (503.68 KiB) Viewed 625 times
- Nictrix
Are manufacturers tyre pressures not related to MPG figures also?
Do higher pressures not give less resistance on the road giving higher MPG?
Im sure I have heard this with push bikes where high tyre pressures make cycling easier as there is less resistance.
As a kid cycling on wet roads seemed easier, i assume less grip resistance.
My 18 inch non rft Asy, i run 38 front 40 rear and get even wear across tyres. When rears were 42, the crown wore more on previous tyres.
Not really..under pressurised by a significant amount does affect rolling resistance…
The manufacturer has to ensure at the maximum possible sustained speed that everything holds together when that speed is maintained for a significant period ie on an autobahn..
Tyres need much higher pressures to cope with that possibility…
Thank you very much, Pbondar, for the reassuring Continental data.
Vidi, vici, veni
I knew you would be pleased about that!-:)
I did follow its advice on my 18" Asymmetric tyres..however even two up the back was 'boing' around..so backed them off to 34/38 ..much better..but I'm not planning a cruise at 155 mph..
- sars
I would be interested in your reasoning of why you think this is so
