Aircon on effect tuning?
- Marcoose
I feel my cars have far more pep after I eat a can of beans. Even more if I add a couple of hard boiled eggs.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
I think there is barely any load, at idle the rpm needle hardly budgies from normal tickover.
Cold air flowing out so pump clutch must have pulled in.
Only jumps a touch as you switch the air con off, probably as fan cuts out.
I'm quite sure in warmer climates folks would start a journey with the aircon on.
Thats odd, your post quotes me as making flybobbies statement!Pondrew wrote: ↑Tue Jun 22, 2021 10:12 pmLet me get this right. You think that driving your 7 miles with the a/c on will help your engine? Seriously?
It will only put the engine under more load when it's cold and use more fuel.
There is a reason why BMW started fitting oil temp gauges instead of the normal water temp ones.
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
Well can effect performance. If the aircon rad is in front of the engine rad. the engine rad will be warmed by air con rad.
By the time the engine thermostat opens to let cooler rad. water in it's already warmed up by the air con rad.
On a cool day with cabin heat on the engine might never reach it's optimum temp. on shortish journeys.
Shutting cabin heat off and running aircon might speed temp. rise up to optimum.
AFAIK the idle is controlled by the ECU..it maintains a constant rpm despite changing accessories loads..so a/c or alternator cycling shouldn’t affect idle speedflybobbie wrote: ↑Wed Jun 23, 2021 6:53 am I think there is barely any load, at idle the rpm needle hardly budgies from normal tickover.
Well having played around to day, don't think it makes much difference.
Mainly i think switching ignition on and letting what sounds like the valvetronic cycling has made it run better.
- Smartbear
I’m not sure the valvetronic system can cycle with the engine turned off as it relies on oil pressure to operate?
e85 3.0si sold
OnlineZed Baron
I guess you do a lot of roof down motoring then
- Marcoose
No way! That would be a horrible waste of fuel. That's my ERS, mate.
I also have on good authority that a well-tuned E89 goes downhill far quicker than uphill.
If you accept that the air con consumes about 10 bhp, then in a 200 bhp car that’s 5% variation..consensus from most tuners is that you will struggle to see that (outside of a dyno / highly structured test track ) unless it affects the shape of the torque / bhp curves…
Valvetronic motor changes the exhaust valve timing, bolted above exhaust on the N52 engine.
Someone on YT replaced their cars motor and did the 10 second ignition on to cycle it, i suppose so it can find the end stops.
I put ignition on can hear a motor winding in and out.
My car certainly received an instant tune up.
- abar121
Doesn't the A/C compressor turn off when the car thinks it's wide open? Most cars do this as well as for heat management.
These days, your car would have to be pretty slow and gutless to notice it on part throttle.
Yonks ago I thought the A/C on my MX5 was faulty. I was crossing Germany at the time and without much traffic, was well above a ton. The car thought it was flat out (or close enough), so kept turning the A/C off. Glad I found out the reason, before submitting a warranty claim!
'07 Z4M Interlagos Blue. All options except extended leather.
No they don't.
No it didn't.
The a/c compressor is controlled by a) the a/c button and b) the pressures switches on the refrigerant lines. That is all.
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- Smartbear
You’re right, I’m confusing valvetronic with vanosflybobbie wrote: ↑Wed Jun 23, 2021 8:44 pmValvetronic motor changes the exhaust valve timing, bolted above exhaust on the N52 engine.
e85 3.0si sold
The voice of sanity and climate protection, I salute you sir
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
