Hill Start Assist - - My car don't have it ?
Hi,
In my sDrive 18i 2013 owners manual says that my car has Hill Start Assist.
In mine it does not work, is there any setup or choice in any menu to set it up?
Thank you
Thank you
- Nictrix
It was done away with on certain models after a certain year but it was not taken out of BMWs literature.
But why, it'a great feature.
- Nictrix
Possibly cost?
- Nictrix
Piece of software costly?
Perhaps it was licenced and they lost it or not prepared to continue paying?
[/quote]
But it wasnt removed from all models.
They removed it from some models for a reason, the main reason normally is cost.
Maybe it was removed from the entry level models just to make the other models have something they didnt.
Maybe it was only removed from the 4 pot models and there is some different software on these.
Whatever it was its strange as it used to be on all models.
- Ole gits rule
[/quote]
That would be my thought - removed from the 18i to give more kit on the 20i
M4 Vert in Yas Marina Blue
- tintoverano
it may be as well that it was coded out by the previous owner of the car for some reason - worth a try to look at it
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
- Smartbear
That would be my thought - removed from the 18i to give more kit on the 20iOle gits rule wrote: ↑Sun Jun 20, 2021 9:43 pmBut it wasnt removed from all models.
[/quote]
The 20i doesn’t have this feature either
e85 3.0si sold
- Smartbear
As far as i know it wasn’t active on any of the 2.0 e89’stintoverano wrote: ↑Sun Jun 20, 2021 10:01 pm it may be as well that it was coded out by the previous owner of the car for some reason - worth a try to look at it
e85 3.0si sold
- Ole gits rule
Possibly cost?
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
Wow - why remove something that is on earlier models especially if it is software - very strange
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
The DSC MK60 unit fitted to E89s supports a wide range of functions..hill start can be coded in the unit on or off along with dozens of other parameters…
It’s therefore not a cost issues..
Why BMW coded it in various ways I don’t know.
Certainly with a ZF8HP box there is no need to switch that feature on.
- Wondermike
- Moderator
- enuff_zed
Quick question from Norfolk:
What is this hill-start magic of which you speak?
I have never noticed the lack of it.
In fact, what's a hill?
- Smartbear
It holds the brakes on for a couple of seconds while you fumble around with your feet trying to find the accelerator
e85 3.0si sold
