Dash cam
birdy_z4
Dash cam
Post by birdy_z4 » Fri Jun 11, 2021 8:04 pm
Hi I went to the fuse box with a hardwire kit which was fairly easy
Fuse box was a pain of course but looks good
quote=Zulu4 post_id=1843571 time=1623399978 user_id=36432]
birdy_z4 wrote: Thu Jun 03, 2021 8:23 pm I’ve just fitted the dash cam below, seems good and a small size so looks good and seems to work well
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
That looks small and neat.
Are you able to get power from the mirror/courtesy light area, or did you go all the way to the fusebox ?
[/quote]
peng
Dash cam
Post by peng » Fri Jun 11, 2021 11:51 pm
Silverstar wrote: Fri Jun 11, 2021 8:45 am How has your Viofo been performing over the 2 years? I have the A119V3 and after some time I found the camera kept switching on and off all the time. Turns out with time the connection between the camera and the GPS base gets loose and hence the constant switching on and off.
I've got the 119 in my wifes car, three years & going strong. In my car also never had any problems with the 129. The only thing I didn't like is the way the power needs to be connected when using the 'hard wire' that is smart enough to start / stop the camera on car ignition & battery voltage availibility: it needs to be connected to the cam to work, rather than to the GPS base. (visible on my picture b.t.w.) I've got all the wires cleanly routed in the car & this would have made it even better. Otherwise, very happy with it!
DMike
Dash cam
Post by DMike » Sat Jun 12, 2021 6:37 am
peng wrote: Fri Jun 11, 2021 11:51 pm
I have had three 119 cams, which I believe are V2, for four years now. One hardwired to my zed, experiencing only summer temperatures, has been working flawlessly all these years. Two hardwired to the daily drivers are exposed to more harsh temperature conditions tend to act up at temperatures below -15˚ and occasionally do keep rebooting, below -25 they usually fail to start but recover once the temperature rises. One of them does not nowadays recognise ignition when the car is cold, and needs to be booted manually, but it’s in a diesel BMW and probably only caused by the glow process and aging car battery. One had problems with the gps base, with a broken pin. To sum up, these V2s have been pretty robust.
2005 Z4 3.0i Sterling grey
Silverstar
Dash cam
Post by Silverstar » Sat Jun 12, 2021 4:06 pm
Yep I saw your photo again and noticed that you have the cable connected to the camera and not to the GPS base. Mine is connected to the GPS base and with time the connection between the GPS and the Camera weakens and causes the camera to keep switching on and off. When connected direct to the camera it's fine but if the GPS connection is not good I would imaging when connected this way I would not be getting any of the GPS features. I've got another GPS base, so I am going to install that hopefully this time it won't give me any problems.
Silverstar
Dash cam
DMike wrote: Sat Jun 12, 2021 6:37 am I have had three 119 cams, which I believe are V2, for four years now. One hardwired to my zed, experiencing only summer temperatures, has been working flawlessly all these years. Two hardwired to the daily drivers are exposed to more harsh temperature conditions tend to act up at temperatures below -15˚ and occasionally do keep rebooting, below -25 they usually fail to start but recover once the temperature rises. One of them does not nowadays recognise ignition when the car is cold, and needs to be booted manually, but it’s in a diesel BMW and probably only caused by the glow process and aging car battery. One had problems with the gps base, with a broken pin. To sum up, these V2s have been pretty robust.
Good to know, I am going to install a new GPS base so hope I have no more issues.
Jasonn
Dash cam
Post by Jasonn » Tue Jun 15, 2021 2:09 pm
Ive just had a look at that, is it possible to disable the blue light? Its something that'd bug me
birdy_z4
Dash cam
Post by birdy_z4 » Wed Jun 16, 2021 8:44 am
Mine is behind the mirror on the passenger side and to be honest I've not really noticed the flashing apart from when I am messing about on the passenger side.
I will take some pictures and upload later today
Carl
Jasonn wrote: Tue Jun 15, 2021 2:09 pm
birdy_z4
Dash cam
Post by birdy_z4 » Thu Jun 17, 2021 6:35 pm
Pictures enclosed
Zulu4 wrote: Fri Jun 11, 2021 9:26 am
PointedMarlin
Dash cam
Post by PointedMarlin » Sat Jun 19, 2021 9:31 pm
So I’m about to purchase a Nextbase 322 & hardwire it but before I do a question to those of you that have hardwired a dash cam
Does it drain the battery if you don’t drive it regularly?
I don’t drive my Zed every day & being a teacher there is the possibility that for 12 weeks of the year it will literally sit on the drive whilst I am driving the family car during school holidays. I don’t want to hardwire it if it’s going to bugger up the battery 🔋
flybobbie
Dash cam
Post by flybobbie » Sat Jun 19, 2021 9:44 pm
I did simple, just run usb cable to arm rest usb socket.
My Viofo is barely visible attached to mirror trim.
Silverstar
Dash cam
Post by Silverstar » Sat Jun 19, 2021 9:49 pm
PointedMarlin wrote: Sat Jun 19, 2021 9:31 pm So I’m about to purchase a Nextbase 322 & hardwire it but before I do a question to those of you that have hardwired a dash cam
I have mine hardwired and it does drain the battery a little but the hardwire kit that I have for my Viofo comes with a battery saver where it basically cuts the power to the camera once the battery voltage drops below a certain point. You can adjust it between 11.8V to 12.4V. This way there is no danger of completely draining the battery.
PointedMarlin
Dash cam
Post by PointedMarlin » Wed Jun 23, 2021 5:14 pm
I have a guy coming round tonight to hardwire this … I hope he’s good 8)
Would people like me to photograph the process so that there can be “How to” hardwire a dash cam using the fuse box provided the guy doesn’t mind & makes a decent job of it?
acm
Dash cam
Post by acm » Thu Jun 24, 2021 12:16 pm
PointedMarlin wrote: Wed Jun 23, 2021 5:14 pm Would people like me to photograph the process so that there can be “How to” hardwire a dash cam using the fuse box provided the guy doesn’t mind & makes a decent job of it?
I would appreciate it if it were possible and your guy is agreeable to being thrust into the limelight :D
Cheers!
Andy
Zforbes
Dash cam
Post by Zforbes » Thu Jun 24, 2021 12:26 pm
Not a 322 but a 312 fitted in mine, piggy back fuse 8 and and the power goes as soon as the ignition is turned off.
Fitting is not difficult but just a bit fiddly when you get to the fusebox
E89 sDrive 35is Titan Silver Kansas Black Leather
Online
Chippie
Dash cam
Post by Chippie » Thu Jun 24, 2021 12:44 pm
PointedMarlin wrote: Wed Jun 23, 2021 5:14 pm I have a guy coming round tonight to hardwire this … I hope he’s good 8)
You can never have too much information and a picture tell a thousand words so please post if you can
