Hi Gents,
Came across the above with manual gear box for cheap. Suddenly it got me thinking what if I swap this with my N20.LOL
Question Gents is it an easy Swap ? Yes many of you will say sell the 28i & buy a 35i. Unfortunately at where I am 35i is
thin to the grown, infact even my 28i is super rare all the rest are 20i. Anyway it's just wishful thinking for the moment.
Perhaps when I get the itch someday.
Cheers & thanks
E90 335i N54 Engine Swap
buy the e90, ditch the z4?
the N54 is a great engine, doesnt matter what chassis its in.
OnlineChippie
I wouldn’t have thought it would be easy or cheap for that matter, just off the top of my head you’d need the ECU, wiring loom, and exhaust, probably cooling pipes/radiator, inter cooler and ducting?, not sure about prop shaft and diff.
Anything is possible you just need deep pockets
- R.E92
I'm not aware of it being done. The engine will swap straight in along with the turbos but the ancillaries and pipework around the engine would need to be changed for 35i versions since the 35i and 335i have different charge pipework. The fuel control and pipework is also different in the 335i. You also have to change the aux belt and tensioner as there's no power steering pump in the Z4. I think once you add up all the parts you need to buy it gets expensive then you need to consider the transmission and diff/axles as the N54 will shred the 28i drivetrain.
I'd sell the 28i and get the 335i honestly. The 3 series chassis isn't as capable but it's much more compliant and the exhaust system that comes on the 335i coupe model sounds much better than the N54 equipped Z4.
Thank Guys well never thought that it was easy.
Can't purchase the 335i as it been chopped up. Lol
Guy asking for only £1500 which includes the ecu as well. No harm nice to day dream at times.
Many thanks again Gents
Last time i checked it was around 200 35i registered in UK! Someone recently posted on here that prices were also rising....sumotan wrote: ↑Thu May 20, 2021 6:41 am Hi Gents,
Cheers & thanks
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
