E89s & Water Pumps
E89s & Water Pumps
There has been a lot posts with owners of E85 and E86 suffering from water pump failures but you don't hear much from E89 owners having this issue. There is also speculation that by the time the E89 came out BMW improved the water pumps so are less troublesome. So the question is how many of us E89 owners have changed their water pumps? and if you did was it due to failure or as preventative maintenance?
E89s & Water Pumps
The 6 pot E89 has an electric water pump, they are apparently pretty poor but on a personal level I have owned a 23i and a 35i with no problems at all.
A bonus is that you can leave the heater on when you lock the car so its warm when you come back with your shopping.
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
E89s & Water Pumps
How do you leave the heater on when you lock the car? I wonder if that would work with the AC in hot weather.
The water pumps look the same as those in the E85 but there are rumours that it was upgraded / modified by the time it got to the 6 pot E89. Seeing as not many E89 owners have reported issues I wonder if this is the case.
- Smartbear
E89s & Water Pumps
I think the heater continues to function with the engine turned off but not with the car locked as far as i know.Silverstar wrote: ↑Mon Mar 01, 2021 9:51 pm How do you leave the heater on when you lock the car? I wonder if that would work with the AC in hot weather.
e85 3.0si sold
E89s & Water Pumps
You turn off the car, press the fan control once and the centre LED illuminates. The car than maintains warmth inside for as long as the coolant remains warm.Silverstar wrote: ↑Mon Mar 01, 2021 9:51 pm How do you leave the heater on when you lock the car? I wonder if that would work with the AC in hot weather.
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- R.E92
E89s & Water Pumps
I changed mine along with the thermostat at 75,000 miles as preventative maintenance. There was no indication that it was going to fail anytime soon and the old pump was in perfect condition.
I wouldn't call it a common failure point but it's one of the few items on the car that can leave you stranded without warning.
If you are going to change it, or have someone else change it, make sure to do the thermostat at the same time as they start to stick open and the thermostat is bolted to the side of the pump.
