Brake caliper paint colour
Depends, if you have it done at a body shop they should have the colour chips for you to choose from, likewise if you get the paint mixed at a car bodyshop supplies outlet if you want to do it yourself. Might take a few minutes to decide but I think it will be worth it in the end.
EDIT: If you go blue then I would get matching DSB as I don't think a different shade of blue would work, although going blue wouldn't give you any contrast.
Looks reet proper that do....
There’s a very small piece of muck on your wheels though.....absolutely no idea where but surely there must be one somewhere....
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
I got mine done in bmw Phoenix yellow metallic ..fior some reason they just don’t seem to show the dirt like bright yellow...mr.tourette wrote: ↑Fri Nov 27, 2020 7:58 pmThat does look interesting, finding the right shade of gold might be challenging thoughSilverstar wrote: ↑Fri Nov 27, 2020 7:07 pm Found a pic blue car gold calipers, get the right shade of gold to match the DSB and I think it will look great also goes with the ivory interior:
- DEA4D4B5-442F-40C6-A561-EFF89F62883D.jpeg (208.52 KiB) Viewed 547 times
- FA10A07D-E71F-4156-BB20-6FC3B2F8663E.jpeg (119.98 KiB) Viewed 547 times
- Attilio
Thank you!
It quite time consuming but I’m really pleased with the end result.
Muck? What muck? Where? Where?
Z4M Coupe, Interlagos blue, black leather, piano black, stubby, OEM CSLs, evolve intake, cup holders...pretty much stock
2019 Toyota Corolla hybrid 2.0L - new daily drive
I’m just trying to make myself feel a little less downcast by my own brake dust ravaged wheels.....Attilio wrote: ↑Sat Nov 28, 2020 12:25 amThank you!
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- mr.tourette
It'll be an in situ job not bodyshop, if i was going blue it would be dark to match, not a fan of the light blue shades, Im definitely considering gold now though, surprised nobody has mentioned black tbh, think I'm favouring carbon gey atm but I'll probably change my mind again before i decide.. tbf the poll has helped me rule out some options but also introduced some not considered previouslySilverstar wrote: ↑Fri Nov 27, 2020 8:28 pm Depends, if you have it done at a body shop they should have the colour chips for you to choose from, likewise if you get the paint mixed at a car bodyshop supplies outlet if you want to do it yourself. Might take a few minutes to decide but I think it will be worth it in the end.
- mr.tourette
So just to draw a line under this I ended up doing none of the above Went with gold, tidied up the hubs with silver and repainted the brake disc guards black just to keep it all neat and tidy, pretty pleased with the end result, seems to work well with the blue bodywork
Looking good!
Might have to do mine now as after getting some new bolts my calipers look quite shabby
Z4 ‘13 20i Mineral Grey
Z4 '07 2.5Si Montego Blue
- mr.tourette
Cheers buddy, know what you mean, my fronts weren't too bad tbh but the rears were really shabby and the hubs were just rusty dark orange, fiddly job but makes a massive differencejamesgarbett wrote: ↑Thu Mar 04, 2021 5:12 pm Looking good!
- Ed.Straker
Looks nice..
On the Z4 the gold/silver/black all look OK..IMHO the blue just looks out of date as do the reds/yellows
White 35i MSport MHD re-map…still in one piece
Atacama Yellow 20i MSport Auto. Remapped, more to be done…written off
What sort of paint did you have to use? Was it just wheels off or calipers too? Did you have to prep them much before painting?
- mr.tourette
I used hammerite smooth.. 8 quid a tin, calipers left in situ with a bit of masking on the pads and on rubber grommets etc, prep wise just a wash down first then a good scrub with a wire brush and using some brake cleaner, you'll spend more time on prep than painting, couple of half inch brushes and i also bought a cheap fine artist brush just to get into awkward spots where i didn't want any excess paint getting on, very satisfying days work
You are a bloke with good taste as I see you went with my suggestion Looks great!
- mr.tourette
Indeed buddy, that pic you put up kinda sealed it, had to spend a bit of time finding the right gold as there seems to be some odd shades kicking about but the hammerite is spot on and as an added bonus cheap as chips at 8 quid a tinSilverstar wrote: ↑Thu Mar 04, 2021 8:03 pm You are a bloke with good taste as I see you went with my suggestion Looks great!
- Mr Tidy
I never thought of it, but they do look good in gold.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
