Bleed brakes with wheels on
Rockhopper
Post by Rockhopper » Fri Nov 20, 2020 1:40 pm
I always do the same.
Smartbear
Post by Smartbear » Fri Nov 20, 2020 1:59 pm
Rucky wrote: Fri Nov 20, 2020 1:37 pm It is common practice to not lubricate wheel nuts.
I personlly disagree and have always lubricated wheel nuts.
Clean Oil and Grease on the Lock nut especially.
Never had a whell come off or loosen, always check after tyre changes.
Also put a film of grease on the alloy wheel where it meets the hub unless you have those plastic shims that go between.
I shall probably be shot down in flames now.
The problem with lubricating wheel nuts is that they no longer receive the correct tightening torque :?
e85 3.0si sold
domsz4
Post by domsz4 » Fri Nov 20, 2020 2:09 pm
i would guess that many garages use a pneumatic system to bleed brakes and change fluid. i have one called a gunsen easy bleed that works very well.
Proud Whip owner ;)
Jasonn
Post by Jasonn » Fri Nov 20, 2020 2:54 pm
I've always used a thin smear of copperslip on the threads
enuff_zed
Post by enuff_zed » Fri Nov 20, 2020 3:05 pm
Jasonn wrote: Fri Nov 20, 2020 2:54 pm I've always used a thin smear of copperslip on the threads
Ok, so given that the torque setting is reached when the resistance to turning of the stud equals the setting on the torque wrench, the stud will stop at a particular point. Now, add a lubricant which makes it easier for the stud to turn. Therefore it will move much further before the resistance equals the torque wrench setting.
Imagine how much extra force you would need to apply to get the stud to move that far without lubrication. Quite a bit.
Therefore, although it could be argued that the torque setting is still the same, the stud must be further in to the thread in the hub, which means it is applying much more force to the seat in the wheel and equally, the stud itself is under much more tension.
Although the turning force applied has effectively been the same amount, the gripping force of the stud holding the wheel is much higher.
In conclusion, I'm with Smartbear and will leave the studs dry, but ensure they are correctly torqued up.
HQ of 'Norfolk Zed Rescue'.
Rucky
Post by Rucky » Sat Nov 21, 2020 10:15 am
Having spent a career in aero engine / aircraft manufacture operation and repair, Iit is standard practice to lubricate all clean nut and bolt threads with clean engine oil or assembly specific lubricants during assembly to achieve correct and consistent torquing -unless they are operating at high temp, are specially coated or sometimes single use.
Commonly to prevent Galling caused by metal on metal contact at high load.
Its a hard habit to break
I agree with your comments regarding resistance to torque , hence the oil for consistency.
I agree that it is equally common practice to assemble un lubricated wheel nuts and studs.
I was just responding to the issue of "I'm just trying to identify which idiot overtightened my locking wheel nuts costing me £100 to get them welded off and replaced today"
Dry nuts and an impact driver incorrectly used do not bode well.
But each to their own ..
04 2.5i Titan silver - 1st Z4 now sold on
07 3.0si Silver Grey M Sport pak.
X5 and assorted motorbikes
enuff_zed
Post by enuff_zed » Sat Nov 21, 2020 12:12 pm
Rucky wrote: Sat Nov 21, 2020 10:15 am Having spent a career in aero engine / aircraft manufacture operation and repair, Iit is standard practice to lubricate all clean nut and bolt threads with clean engine oil or assembly specific lubricants during assembly to achieve correct and consistent torquing -unless they are operating at high temp, are specially coated or sometimes single use.
Having spent a career in Military aero engine / aircraft operation and repair, it was standard practice to NOT lubricate all clean nut and bolt threads with clean engine oil or assembly specific lubricants during assembly to achieve correct and consistent torquing. Our approach was to replace the fastener if there was the slightest doubt, and assemble it dry.
But each to their own .. :thumbsup:
Jasonn
Post by Jasonn » Sat Nov 21, 2020 4:08 pm
I think I got into the habit of a thin amount of copperslip when I had to change the wheel on my hillman imp - imagine 4 spotty 17 year olds trying to loosen the damn wheel nuts which finally gave with a horrible squeal/screech as each one gave.
After that experience I always applied a very thin smear right at the end of the stud (or bolt depending on the vehicle) just to act as a preventative measure. Its probably psychological and has no scientific basis, but each to their own.
BadgerDog
Post by BadgerDog » Tue Nov 24, 2020 5:07 am
enuff_zed wrote: Sat Nov 21, 2020 12:12 pm
In either case the take away should be: know the proper procedure for the equipment you are working on and use it, otherwise the torque setting will be incorrect. Lubricating is perfectly fine... if the specified torque settings take that into account, and vice versa.
I do not have any source as to whether or not BMW publishes torque specs expecting lubricated bolts, but I am gunna go ahead and assume NOT since most folks and shops don't and they know it (and not lubricating when the spec assumes lube is more dangerous than the opposite as you end up under tightening).
So in conclusion: do what the manufacturer expects!
ph001
Post by ph001 » Tue Nov 24, 2020 10:44 am
Also from an engineering background... I routinely apply a light coating of copperslip to the wheel bolt threads but NEVER to the chamfer on wheel bolt head. It is the friction between the bolt head and the recess on the alloy that results in an accurate torque setting.
BadgerDog
Post by BadgerDog » Wed Nov 25, 2020 9:20 am
ph001 wrote: Tue Nov 24, 2020 10:44 am Also from an engineering background... I routinely apply a light coating of copperslip to the wheel bolt threads but NEVER to the chamfer on wheel bolt head. It is the friction between the bolt head and the recess on the alloy that results in an accurate torque setting.
What type of engineering (electrical / mech / etc)? I dont think thats correct, but Im not 100% sure. ALL friction sources should contribute to the torque required to move the bolt incrementally. If you reduce any one of them the others have to "work harder" to make up the difference and you will still over tighten. At least thats my take, but Im an electrical / software engineer so while I have the general background its not my specialty.
Jasonn
Post by Jasonn » Wed Nov 25, 2020 11:07 am
I only use a thin smear on the threads and the only reason is to prevent them rusting/corroding, which was a real PITA when I had a puncture many years ago (now have breakdown cover as well) but old habits die hard.
ph001
Post by ph001 » Wed Nov 25, 2020 11:59 am
BadgerDog wrote: Wed Nov 25, 2020 9:20 am What type of engineering (electrical / mech / etc)?
Electronics! So nothing really to do with the subject matter :rofl:
BadgerDog
Post by BadgerDog » Sat Nov 28, 2020 5:35 am
ph001 wrote: Wed Nov 25, 2020 11:59 am
Fair enough! I wasnt trying to call you out, just curious.
Pbondar
Post by Pbondar » Sat Nov 28, 2020 11:04 am
ClumUK wrote: Wed Nov 18, 2020 1:19 pm Quick question for you guys, 35is with 19" wheels, can the brakes be bled with the wheels left on? And if so, would a garage choose to do it this way when carrying out a brake fluid change as part of a service?
To come back to the original post...surely you would like to check the pads etc to coincide with a fluid change and a general check of linkages / suspension etc?
Logically you would normally group similar activities together?
It’s not a personal criticism more just good maintenance practice?
