Recommend new battery (and weird noise)
Bizarre though don’t you think? Two different words for what amounts to a near identical process and just adds confusion to most people
Thanks for all replies. Going to get one with the same specs then register it in the car.
You can code start/stop to always be off and not default to on with Carly right? Think I’m going to get Carly...been thinking about it for a while but never did so and these two procedures might pay for itself and then I can play with other settings.
Is there a sign these are failing? I ask because I saw a YouTube video once showing a car that had the beginnings of problems and under the bonnet was a whine when revving.
My car makes a whine type noise in 1st and 2nd when accelerating but after that it’s not present (or noticeable). But I’m not sure if it’s the turbo?
Does this sound related?
Yes, it’s a 2011 20i so falls into that category.Pbondar wrote: ↑Mon Sep 21, 2020 6:21 pm As an aside if you have a 18i 20i 28i with Stratton stop then it’s best NOT to use it and also get into a 5,000 / annual oil change regime in a bid to save further damage to the cam chain and it’s tensioner if your E89 is pre 2015 model year..even if it’s later still good practice..
2011 E89 sDrive20i
I’m not sure what the whine is but it’s probably NOT cam chain related...IMHO..
Thanks.
It starts at about 1750rpm going towards and past 2000rpm and only really seems noticeable in 1st and 2nd when accelerating, there is plenty of pull etc.
I think I'm losing it, as this could just be the normal sound in the lower gears, perhaps due to gearing? Almost like an electric motor sound, but not like an electric motor sound. My description makes no sense, I am aware of that
2011 E89 sDrive20i
People on this Forum often lose it so I wouldn't worry on that score..ihadablackdog wrote: ↑Tue Sep 22, 2020 2:50 pmThanks.
Sounds like transmission related noise..is it manual?
'pull' wise is not relevant..the N20 engines 'pull' till the cam chain jumps the camshaft sprockets, then there is 'no pull'
Doing an oil change and cutting open the filter is a good diagnostic..if you have plastic swarf in there then its on its way to 'good night vienna'
Yes, its a manual. I'll try and check if it happens when in neutral or only when actually in gear.
2011 E89 sDrive20i
Often you get a minor bit of whine from manual box and/or rear diff ..ihadablackdog wrote: ↑Tue Sep 22, 2020 3:25 pm Yes, its a manual. I'll try and check if it happens when in neutral or only when actually in gear.
Camchain wise if you remove oil filler cap and peer with torch if you see ANY swarf espcially a brown plastic then you are in deep doo-doo
Thanks.
I’ll look in the oil cap and see if I can see anything.
Did have an oil service a month or two ago but will let you know what I find.
2011 E89 sDrive20i
So here's some videos:
This is the one I referred to earlier, that has the whining noise (only need to listen to first 25 secs)
Here's mine. Deb was in the car revving to 2k rpm and kind of holding it at that level. Don't know why I kept moving the camera.
...and heres an unrelated video of a monsoon earlier in the year! (sh1t my pants!)
2011 E89 sDrive20i
Changed mine to 80ah to give a bit more...
Yup it’s a first generation tensioner / guide ..looks ok AFAICT
Yeah thats an eye opener if I ever saw one. Great response.ihadablackdog wrote: ↑Tue Sep 22, 2020 9:56 pm ...and heres an unrelated video of a monsoon earlier in the year! (sh1t my pants!)
I was very lucky not to crash - luckily the bit where I was heading for the curb was just level grass, not a curb stone etc. I bet the mini bus driver chuckled at my misfortune.BadgerDog wrote: ↑Wed Sep 23, 2020 8:52 amYeah thats an eye opener if I ever saw one. Great response.ihadablackdog wrote: ↑Tue Sep 22, 2020 9:56 pm ...and heres an unrelated video of a monsoon earlier in the year! (sh1t my pants!)
Never seen it flood there before so wasn’t expecting it, should’ve probably been a bit slower as it was raining but hey ho, was fortunate that day. I was on the Goodyear non run flats, wonder what the outcome would’ve been on runflats?
2011 E89 sDrive20i
