Walnut Blasting
Walnut Blasting
So I understand the idea behind it and what it buys you, etc. I'm just trying to get a feel for how often. I have to assume its never been performed on my car, which is a 2016. Is it about that time, or too early to be wasting money on it? A QUICK search found one place that will do it for $250, and it sounds like something I could do myself (already have a nice air compressor, would just need a blasting tool, which is cheap enough). Possible I could find it cheaper elsewhere, but regardless, what say the collective?
- Smartbear
Walnut Blasting
What model z4 have you got? Not all of them need walnut blastingBadgerDog wrote: ↑Sun Sep 06, 2020 5:58 am So I understand the idea behind it and what it buys you, etc. I'm just trying to get a feel for how often. I have to assume its never been performed on my car, which is a 2016. Is it about that time, or too early to be wasting money on it? A QUICK search found one place that will do it for $250, and it sounds like something I could do myself (already have a nice air compressor, would just need a blasting tool, which is cheap enough). Possible I could find it cheaper elsewhere, but regardless, what say the collective?
e85 3.0si sold
Walnut Blasting
2016 Z4 sDrive35i. Estoril blue if the color matters. (Kidding, haha)
Joking aside, I was under the impression that all of the fuel injected engines can end up needing it because they dont get fuel washing over the valves. Wouldnt that be ALL of the zeds?
Walnut Blasting
What size is your compressor Badgerdog...? Unless you’ve got something with at least 200litres with up to 145psi capability and a flow rate of around 12 CFM you’ll not do it I’m afraid AFAIK, that’s what you need for soda blasting for example so I’m assuming it’s the same for walnut too. These things chew air like you wouldn’t believe.BadgerDog wrote: ↑Sun Sep 06, 2020 5:58 am So I understand the idea behind it and what it buys you, etc. I'm just trying to get a feel for how often. I have to assume its never been performed on my car, which is a 2016. Is it about that time, or too early to be wasting money on it? A QUICK search found one place that will do it for $250, and it sounds like something I could do myself (already have a nice air compressor, would just need a blasting tool, which is cheap enough). Possible I could find it cheaper elsewhere, but regardless, what say the collective?
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Walnut Blasting
Oh dang. If the needs are really that high then I'm out. Its decent but not that good (cant recall exact specs off hand though).
Walnut Blasting
You can always use CRC Intake Cleaner as an alternative method, remove intake manifold as per walnut blasting but then use a strong chemical that dissolves the carbon build up. I did it earlier this year and it works a treat. It is detailed on a previous thread on here
viewtopic.php?f=23&t=120044&p=1717627&h ... g#p1717627
- DMike
Walnut Blasting
As far as I’ve read, not necessary for the M54s. Or perhaps for them just find a nice long winding road through a forest with walnut trees, then blast until valves are red . When I first time heard ”walnut blasting” this instant Schwarzwald association was the first one that came to my mind...
2005 Z4 3.0i Sterling grey
- R.E92
Walnut Blasting
I had it done a few years ago at 50,000 miles at a BMW dealer while in for warranty work, they said the valves weren't that dirty to begin with. Total cost was £250 which included all replacement gaskets.
I almost always prefer to DIY but £250 is the going rate even at specialists so at that price it seems a no brainer to farm it out. The cost of buying all the equipment means that unless you are going to do multiple vehicles it doesn't save any money.
- Chippie
Walnut Blasting
I’d say the valves would need doing about every 60,000 miles as mine we’re getting quite a build up by then
- MACK
Walnut Blasting
You only really need to be considering this on DFI engines where the valves aren't fuel washed by the injectors, which eliminates all the E85 variants and only leaves the turbo E89's. I'm led to believe the older N54/5's are worse in this respect than than N20 due to the design of their breather systems, but none of the BMW engines are as bad as some VW/AUDI ones
Silver 05 3.0i SE
White E89 20i M Sport
Walnut Blasting
What is walnut blasting? Is it Apr 1?
- Smartbear
Walnut Blasting
It’s the use of ground walnut shell as a medium for blasting carbon build up from the intake valves/ports
e85 3.0si sold
Walnut Blasting
Oil catch can is a must, I fitted the mishimoto kit earlier this year after reading comments by multiple performance suppliers/tuners that it is the first step with any direct injection engine.
My post on fitting to 35i is here ....
viewtopic.php?f=23&t=119149&p=1705789&h ... n#p1705789
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
Walnut Blasting
DMike wrote: ↑Sun Sep 06, 2020 9:52 am As far as I’ve read, not necessary for the M54s. Or perhaps for them just find a nice long winding road through a forest with walnut trees, then blast until valves are red . When I first time heard ”walnut blasting” this instant Schwarzwald association was the first one that came to my mind...
