My current project - Retrofit iDrive
AnubisZed
Post by AnubisZed » Fri Jun 11, 2021 8:55 am
birdy_z4 wrote: Thu Jun 10, 2021 11:20 am Thanks Dave, do you have any part numbers at all ?
Carl :D
OK, well this isn't quite set in stone, so I'll give you the proper numbers and the ones I got.....
Corect numbers;
DAB module = Now there are a number of different modules throughout the years, so starting with the earliest up to the latest;
65129119354 (09/01/2006 - 05/16/2006)
65129119355 (09/01/2006 — 03/02/2007)
65129119357 (03/01/2007 — 10/05/2007)
65129119359 (08/01/2007 — 04/09/2009)
65129176958 (03/01/2008 — 03/19/2011)
65129216459 (03/01/2010 — )
Bracket
9136696
Bolt
9902932 (M5 x 14) x3
Nut
9904022 (M6) x4
Antennas;
L-Band (above interior light)
9123784
Band-III (inside rear bumper right side)
9123995
I haven't found the part numbers for the correct cables from the antennas to the module.
Now for the non-original parts I've got;
(Module and bracket are the correct ones, the bracket was bought brand new)
Bolts
https://www.ebay.co.uk/itm/160855087619 ... 0101909138
Nuts
https://www.ebay.co.uk/itm/150792649468 ... 0073161423
Antenna
https://www.aliexpress.com/item/3296539 ... 4c4dQKQnrQ
Antenna twin adaptor
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
MOST line (size is dependent on where you run to)
https://www.aliexpress.com/item/3280035 ... 4c4dttX0Uf
MOST Y line
https://www.aliexpress.com/item/3274905 ... 4c4dttX0Uf
I think that about covers all of it :thumbsup:
Dave
2011, 23i, Grey with Red leather. 8)
birdy_z4
Post by birdy_z4 » Fri Jun 11, 2021 8:56 am
Dave your a star, many thanks
birdy_z4
Post by birdy_z4 » Wed Jun 16, 2021 1:30 pm
Dave will you be doing a VID on the Combox and DAB installations ?
AnubisZed wrote: Fri Jun 11, 2021 8:55 am
Carl :D
Corect numbers;
Bracket
9136696
Bolt
Nut
9904022 (M6) x4
Antennas;
9123784
9123995
Bolts
Nuts
Antenna
MOST Y line
AnubisZed
Post by AnubisZed » Wed Jun 16, 2021 7:38 pm
birdy_z4 wrote: Wed Jun 16, 2021 1:30 pm Dave will you be doing a VID on the Combox and DAB installations ?
Yes that is my intention, although I've not filmed anything for the combox and I've not really started the DAB, and I already have at least two other videos to finish first, so it won't be for some time yet :(
Dave
birdy_z4
Post by birdy_z4 » Thu Jun 17, 2021 11:09 am
Noted where did you get the combos to mild connector / adaptor looking on eBay they are pretty expensive
AnubisZed
Post by AnubisZed » Thu Jun 17, 2021 11:39 am
birdy_z4 wrote: Thu Jun 17, 2021 11:09 am Noted where did you get the combos to mild connector / adaptor looking on eBay they are pretty expensive
For mine I just bought a genuine one, but since then I've found out that the VW 26 pin connector does the same job, so I've tried one of these on a customers car and it was perfect...
https://www.ebay.co.uk/itm/265171215863 ... SwDOpb2YIu
Dave
birdy_z4
Post by birdy_z4 » Thu Jun 17, 2021 2:47 pm
Thank you Dave
AnubisZed wrote: Thu Jun 17, 2021 11:39 am
Deepseaskateboard
Post by Deepseaskateboard » Sun Jul 04, 2021 3:05 pm
Is it possible to do a hybrid of taking the Android screen and hardware and fitting it to the OEM flip up module?
So, removing the oem screen from it’s housing, and then replacing with the android screen and associated electrical gubbins.
I bet you have thought of the same idea, just wondering if it would fit at all?
AnubisZed
Post by AnubisZed » Sun Jul 04, 2021 3:46 pm
Deepseaskateboard wrote: Sun Jul 04, 2021 3:05 pm Is it possible to do a hybrid of taking the Android screen and hardware and fitting it to the OEM flip up module?
Oddly enough, yes I have thought of thus, as well as a guy in the US and another somewhere in Europe. We all discussed it at some length and the biggest stumbling block is that the control and power for the up and down motor is from the same pcb as the screen, so somehow you'd have to find the correct circuit and then build som sort of new pcb to retain the flip action. We decided it simply wasn't worth it, and assuming that why the Android screen was built to way it was. Someone may come up with ut eventually, you never know.
Personally, for what I use it for anyway, I find the addition of the MMI box enough on a day to day basis.
Dave
Deepseaskateboard
Post by Deepseaskateboard » Sun Jul 04, 2021 5:02 pm
AnubisZed wrote: Sun Jul 04, 2021 3:46 pm
Interesting, presumably there is some simple logic: if power on activate motor for x micro seconds and vice versa. etc.
An Arduino Nano could be programmed to perform this function on the motor.
The reason why I am interested is, the screen units seem quite easy to source, where as the whole retrofit for OEM requires finding some pretty rare items, like the cage mount for the Navigation DVD unit.
I guess part of the issue with trying it, is that you are left with a pile of expensive parts which no longer work for either solution if it does not work or fit!
Deepseaskateboard
Post by Deepseaskateboard » Thu Aug 05, 2021 6:15 pm
Hi Dave,
Another question… can you forsee any fitment or coding issues fitting an LCI idrive system to a pre LCI car?
AnubisZed
Post by AnubisZed » Thu Aug 05, 2021 8:33 pm
Deepseaskateboard wrote: Thu Aug 05, 2021 6:15 pm
Hi Dave,
Not sure what you mean by LCI iDrive system?
So thinking of 2 directions here....
If you mean pre and post 2013, then the only differenceis that the post screens have is a shiny surround, nothing else is different at all.
If you mean CIC to NBT then without major surgery, that's not possible (well it is but it'll be a bit of a Frankinstein's monster of a hack job!!).
And just to clarify there, ALL E89's that had iDrive were CIC right up to end of production in 2016, even though all other BMW's were NBT from 2013.
My iDrive retrofit was using a 2015 screen and a 2013 headunit in my 2011 Z, absolutely no issues whatsoever :thumbsup:
Dave
Deepseaskateboard
Post by Deepseaskateboard » Thu Aug 05, 2021 8:51 pm
AnubisZed wrote: Thu Aug 05, 2021 8:33 pm
Hi Dave,
Thanks, I did mean a post 2013 system (with shiny screen surround) to a 2012 car.
I found something on ebay and I am pondering…
AnubisZed
Post by AnubisZed » Fri Aug 06, 2021 8:38 am
Deepseaskateboard wrote: Thu Aug 05, 2021 8:51 pm Thanks, I did mean a post 2013 system (with shiny screen surround) to a 2012 car.
Yep no problemthen, it's a 4 pin LVDS and 4 pin power/canbus connection just the same :thumbsup:
Dave
AnubisZed
Post by AnubisZed » Tue Mar 15, 2022 7:36 pm
Sorry to drag up an old post :D
If anyone is considering a full iDrive retrofit then on eBay at the moment is a headunit, screen and iDrive controller up for £749.
Link here>>> https://www.ebay.co.uk/itm/275198765445
**1 Nothing to do with me, not my sale, just an heads-up in case anyone was interested.
**2 Bear in mind the other components that are required that do not come with this eBay sale.
Dave
