Airfly Pro
- Deepseaskateboard
Airfly Pro
The Airfly Pro is a cool little dongle which connects into the aux socket, then via bluetooth to your phone.
Great for spotify!
The airfly has a small battery and is charged via usbC
It can also send audio to wireless headphones, but for car purposes, it works very well indeed.
Just showing what it does, can pick them up on ebay for around £30!
Happy hunting! (Usually £50)
Great for spotify!
- 3AED8747-FB02-425D-9BB4-E5FB5BC406FF.jpeg (438.04 KiB) Viewed 1191 times
- Timmyboybunter
Airfly Pro
I went for the similarly named 'Tunai Firefly', also £30.
Main difference is it also plugs into the USB so no charging/turning on and off required
2019 G21 M340i Touring xDrive
2015 E89 BMW Z4 sDrive35iS (sold)
2010 E89 BMW Z4 sDrive30i (sold)
2003 E85 BMW Z4 3.0 (sold)
Airfly Pro
Would it work if you plugged it into the glovebox USB??Timmyboybunter wrote: Fri May 22, 2020 11:54 pm I went for the similarly named 'Tunai Firefly', also £30.
Main difference is it also plugs into the USB so no charging/turning on and off required![]()
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- tintoverano
Airfly Pro
I don't think that one can be used for charging, low ampermcbutler wrote: Sat May 23, 2020 7:45 amWould it work if you plugged it into the glovebox USB??Timmyboybunter wrote: Fri May 22, 2020 11:54 pm I went for the similarly named 'Tunai Firefly', also £30.
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
Airfly Pro
All USB connectors are mandated to supply 5v power and data in/outtintoverano wrote: Sat May 23, 2020 8:10 amI don't think that one can be used for charging, low ampermcbutler wrote: Sat May 23, 2020 7:45 amWould it work if you plugged it into the glovebox USB??Timmyboybunter wrote: Fri May 22, 2020 11:54 pm I went for the similarly named 'Tunai Firefly', also £30.
The low power version is 100ma
So providing the charging circuit doesn’t ask too much it MAY be possible to plug it into the glove box USB port...you could just try it..
- Timmyboybunter
Airfly Pro
But... you need to plug it into the 3.5mm audio jack in the armrest to get the sound.
- Deepseaskateboard
Airfly Pro
You can keep the airfly plugged into the usb if you want.
Battery is good for a weekend though.
- Deepseaskateboard
Airfly Pro
Deepseaskateboard wrote: Sat May 23, 2020 10:52 am You can keep the airfly plugged into the usb for power if you want. I use a 12v to usb adapter.
- Timmyboybunter
Airfly Pro
The USB port switches off a couple of minutes after locking the car, so no battery drain concerns - makes that a good option
- Zed Baron
Airfly Pro
Ive got this fitted in my Toyota for the last 4 years, allows you to skip tracks and answer phone calls. Sound quality is very good for £15! https://www.amazon.co.uk/TECEVO-Bluetoo ... 43&sr=8-61
Airfly Pro
Ah well spotted..thank you..much better to have had the luck /forsight to get the factory fitted option!Timmyboybunter wrote: Sat May 23, 2020 10:23 am But... you need to plug it into the 3.5mm audio jack in the armrest to get the sound.
Airfly Pro
I have something similar with no issues since ownership of the vehicle. No dedicated usb specced out in mines unfortunately so had to result in this. USB end powered via cigarette lighter port and the other in aux.
https://a.aliexpress.com/_d6SvLlx
- Timmyboybunter
Airfly Pro
Does the cigarette lighter socket also switch off a few mins after locking the car, out of interest?
Airfly Pro
YesTimmyboybunter wrote: Sun May 24, 2020 12:43 pm Does the cigarette lighter socket also switch off a few mins after locking the car, out of interest?
Airfly Pro
I am probably asking a bit much here, but I am guessing you have no control over your phone from the head unit / steering wheel controls with these devises?
All track skips etc would need to be done via the phone?
2013 Z4 20i sDrive.
Remapped, and currently “interior” rattle free.
Early midlife crises and so far loving every minute of it!
