I am pretty sure the fan is electric and not connected to the engine at all!!scootr wrote: ↑Wed Feb 12, 2020 9:41 pm I'd bet you might be able to turn her over by hand without the plugs? Worth a try, just grab the fan and turn once the plugs are out... you are replacing plugs now too? I was going to suggest you take pics of everything you are going to remove - for yourself. Having watched the manifold removal on line I see a bunch of stuff needs disconnecting. That can get confusing for not much DIYer guy upon reassembly
Doing an Intake Valve Clean - any tips?
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- scootr
[/quote]
[/quote]
I'm pretty sure you are absolutely correct and I am very old fashion.
[/quote]
E89 3.0L 6 MT gone
Michelin P4s
Bilstein struts & shocks
Luxon tower brace
Michelin P4s
Luxon tower brace
enzed4, to revive an old thread, I see you had a BMS charge pipe on its way to you. Without going into details of my own issues in this regard, I was under the impression that they do not make one to fit a Z4. It could just be that you have a 2010 and I have a 2016, though. I'm assuming the parts are not interchangeable between the two.
- enzed4
Sorry for the slow reply - I haven't been on here for a while.BadgerDog wrote: ↑Sun Sep 06, 2020 9:30 pm enzed4, to revive an old thread, I see you had a BMS charge pipe on its way to you. Without going into details of my own issues in this regard, I was under the impression that they do not make one to fit a Z4. It could just be that you have a 2010 and I have a 2016, though. I'm assuming the parts are not interchangeable between the two.
You are correct about the charge pipe. I must have been half asleep when I ordered it because it's for a 335i not a Z4 35i. My son has a 335i so the intention was to fit it to his car but that still hasn't happened yet and it's sitting in my garage mocking my poor research skills every time I look at it.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
This is mine being done by Redish Motorsport in Bristol.
https://youtu.be/5L7Gc436rB4
Car had only done 40k miles.
£400 including new gasket. Cheapest I've seen is £250 by PMP cars near Birmingham. I went with Redish as they can do DCT service.
Had M3/4 Brembo front calipers fitted with 370mm discs.
- 20201002_151925.jpg (204.96 KiB) Viewed 394 times
- 20201002_151939.jpg (158.87 KiB) Viewed 394 times
- enzed4
That was a very good/clear video of the walnut blasting - I wish someone here offered the service, I don't know if I could be bothered with the hassle again. Now that I'm familiar with the process of getting everything off down to the intake ports, even a DIY blasting kit would probably be ok if good quality.richg wrote: ↑Fri Oct 02, 2020 6:56 pm This is mine being done by Redish Motorsport in Bristol.
Nice Brembos, too
Gone: 2010 35i DCT
Ahhh, gotcha. Thanks!enzed4 wrote: ↑Thu Oct 01, 2020 10:10 pm Sorry for the slow reply - I haven't been on here for a while.
I got caught up by the misleading title: "N54 charge pipe for e-chasis BMWs". Figured, I have one of those! lol My mistake.
