Now thats bad luck
Now thats bad luck
Hi all ,so today was the day i got to pick my z4 up i bought off a forum member z4sparky ,deal couldnt have been smoother & hes a top man to deal with.Anyway drove home ,with slight diversion along duel carriage way so i could give it a little blast ,all well & good & delighted with the way it drove.Got home ,had a bite to eat & then decided to fill it up & have a cruise ,road i normaly used was closed due to a sink hole ,took alternative route like everone else .Got half way along said road then bang hit a beep beep beep pot hole disguised as a puddle .Stopped had a look mark in wheel grrrr but eh ho thats life .Got to garage by which time tyre was flat ,had to get put on transporter & taken home ..sob sob..So i managed approximately 20 miles in my new car & nows its out of action until i get tyre replaced .Could of been worse but thats bad luck.cheers
- Smartbear
Now thats bad luck
Have a good look, it may be a cracked wheel that’s lost the tyres pressure, they usually go on the inside rimlavy1966 wrote: ↑Sun Jan 19, 2020 4:56 pm Hi all ,so today was the day i got to pick my z4 up i bought off a forum member z4sparky ,deal couldnt have been smoother & hes a top man to deal with.Anyway drove home ,with slight diversion along duel carriage way so i could give it a little blast ,all well & good & delighted with the way it drove.Got home ,had a bite to eat & then decided to fill it up & have a cruise ,road i normaly used was closed due to a sink hole ,took alternative route like everone else .Got half way along said road then bang hit a beep beep beep pot hole disguised as a puddle .Stopped had a look mark in wheel grrrr but eh ho thats life .Got to garage by which time tyre was flat ,had to get put on transporter & taken home ..sob sob..So i managed approximately 20 miles in my new car & nows its out of action until i get tyre replaced .Could of been worse but thats bad luck.cheers
e85 3.0si sold
Now thats bad luck
I will do thanks Rob ,cant see much without taking wheel off so ill check when i do ,at the mo just a nick in outside of rim & tyre wont inflate ,so i suspect it might well be a crack on inside or hopefully a puncture i cant see .cheers
- buzyg
Now thats bad luck
Not the best start. Hopefully as soon as she's back on the road twill all be forgot.
Now thats bad luck
That's bad luck,I would get back to the pot hole, take photos and try and claim off the council. What wheels do you have ?
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Argyll Andy
Now thats bad luck
After me pitching for the 296’slavy1966 wrote: ↑Sun Jan 19, 2020 4:56 pm Hi all ,so today was the day i got to pick my z4 up i bought off a forum member z4sparky ,deal couldnt have been smoother & hes a top man to deal with.Anyway drove home ,with slight diversion along duel carriage way so i could give it a little blast ,all well & good & delighted with the way it drove.Got home ,had a bite to eat & then decided to fill it up & have a cruise ,road i normaly used was closed due to a sink hole ,took alternative route like everone else .Got half way along said road then bang hit a beep beep beep pot hole disguised as a puddle .Stopped had a look mark in wheel grrrr but eh ho thats life .Got to garage by which time tyre was flat ,had to get put on transporter & taken home ..sob sob..So i managed approximately 20 miles in my new car & nows its out of action until i get tyre replaced .Could of been worse but thats bad luck.cheers
Hopefully just a puncture and the rims ok
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
- Stevo1987
Now thats bad luck
C'mon, it is hardly a failed gearbox...
2014 Z4 e89 35is in mineral grey.
2012 Audi TTS in Ibis white.
Onlineronk
Now thats bad luck
Of course the council will tell you that they inspected that road within the required period - if they do (as i suspect they will) ask for evidence of the inspection.
OnlineMr Tidy
Now thats bad luck
What a pain!
Your day started so well too. I hope you can get your wheel/tyre sorted painlessly.
Then you can enjoy your Z4.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
