E89 roof relay change
Smartbear
Post by Smartbear » Thu Dec 26, 2019 4:39 pm
Hi, not wanting to watch the endless repeats on tv over the crimbo period, i thought I’d change the 2 salmon relays that operate the roof.
The first thing to do is clear the boot of any blankets etc :P
You can see the salmon relays in this pic, the white coloured clips are fiddly to release in this position
If you undo the T25 torx securing the mounting bracket the job becomes a lot easier
The relays pull out after releasing the white clips & wiggling a little
After swapping the relays over for a new pair it makes sense to check the roof still operates correctly :thumbsup:
I also took the opportunity to look at the old relays in more detail, the orange cover pulls off after releasing some small clips underneath & you can now operate the relay manually to check for burnt contacts (which cause potentially massive problems if they weld together or go high resistance)
My car has covered 37k since 2013 & the contacts still looked good imho, as the pair only cost around £30 it’s cheap insurance to change them though :thumbsup:
e85 3.0si sold
clarker63
Post by clarker63 » Thu Dec 26, 2019 7:53 pm
Nice job Rob.. and I like the bear blankets ! :thumbsup: Rob
35is, sadly gone, but not forgotten.
Silverstar
Post by Silverstar » Thu Dec 26, 2019 9:40 pm
Helpful write up Rob. That reminds me I need to do mine since the car is 10 years old and god knows if they have been done! what's the cable with the red crimp connectors for?
Smartbear
Post by Smartbear » Thu Dec 26, 2019 11:00 pm
Silverstar wrote: Thu Dec 26, 2019 9:40 pm Helpful write up Rob. That reminds me I need to do mine since the car is 10 years old and god knows if they have been done! what's the cable with the red crimp connectors for?
Hi, I’ve wired in a plug for a smartcharger that stays in situ :thumbsup:
e85 3.0si sold
Timmyboybunter
Post by Timmyboybunter » Thu Dec 26, 2019 11:13 pm
Smartbear wrote: Thu Dec 26, 2019 11:00 pm Hi, I’ve wired in a plug for a smartcharger that stays in situ :thumbsup:
Presumably no issue doing this Rob? I did this on my E85 but read it was not recommended on the E89 and the connections in the bonnet should be used instead.
2012 VW Passat 1.4 Tsi Estate
2005 Mercedes CLK 55 AMG
2015 E89 BMW Z4 sDrive35iS (sold)
2010 E89 BMW Z4 sDrive30i (sold)
2003 E85 BMW Z4 3.0 (sold)
Smartbear
Post by Smartbear » Thu Dec 26, 2019 11:40 pm
Timmyboybunter wrote: Thu Dec 26, 2019 11:13 pm
Someone that knows more about the complexities of the car will be along later i suspect, but my cars been fine :thumbsup:
e85 3.0si sold
Timmyboybunter
Post by Timmyboybunter » Fri Dec 27, 2019 12:02 am
That's good enough for me :rofl:
Jasonn
Post by Jasonn » Fri Dec 27, 2019 12:09 am
Evening all, as I'm new to zed ownership, how often should this be done? Mine is 2016 and has 37k on the clock - do these salmon relays have a particular name so that I don't get a weird look from my local auto factor?
Frankie169
Post by Frankie169 » Fri Dec 27, 2019 12:13 am
What’s the part numbers for the relay, fancy order some myself, just in case!,
Toys: Z4 E89 35i in Blue / Ducati Multistrada 1260 DVT + love my watches
Smartbear
Post by Smartbear » Fri Dec 27, 2019 12:51 am
Frankie169 wrote: Fri Dec 27, 2019 12:13 am What’s the part numbers for the relay, fancy order some myself, just in case!,
Hi, part number starts with 12 :thumbsup:
e85 3.0si sold
Smartbear
Post by Smartbear » Fri Dec 27, 2019 12:52 am
Jasonn wrote: Fri Dec 27, 2019 12:09 am Evening all, as I'm new to zed ownership, how often should this be done? Mine is 2016 and has 37k on the clock - do these salmon relays have a particular name so that I don't get a weird look from my local auto factor?
Hi, I’ve read an expert recommended every 5 to 6 years to be safe, it’s a nightmare if they go bad :cry:
e85 3.0si sold
Stuartt
Post by Stuartt » Fri Dec 27, 2019 1:00 am
Good job well done there Bear :thumbsup:
Stuart
2004 3.0i SE Roadster , GONE to a good home :thumbsup:
2010 e89 35i Sdrive M sport. GONE for salvage :cry: but has been reborn
2014 e89 35is M-Sport Design Pure Traction 😈😈😈
Jasonn
Post by Jasonn » Fri Dec 27, 2019 8:33 am
Smartbear wrote: Fri Dec 27, 2019 12:52 am
Thanks for the heads up :thumbsup:
enzed4
Post by enzed4 » Fri Dec 27, 2019 9:00 am
Thanks for the write up :thumbsup: . Any need to disconnect battery before replacing the relays? I guess not...
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
Smartbear
Post by Smartbear » Fri Dec 27, 2019 11:10 am
enzed4 wrote: Fri Dec 27, 2019 9:00 am Thanks for the write up :thumbsup: . Any need to disconnect battery before replacing the relays? I guess not...
I left the battery alone, there’s nothing between the relay & battery that lets you turn off the power if a relay mechanically sticks up via a welded together contact, that’s why it’s such a nightmare if that occurs. The roof motor will run until the battery flattens or the motor catches fire & turning the car off won’t stop it!
A replacement motor from bmw is over £2500 :cry:
e85 3.0si sold
