E89 roof relay change
- tintoverano
couldn't replacing the micro switches wait till they start producing the symptom?
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
- RobbiZ4
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
- RobbiZ4
- tintoverano
RobbiZ4 wrote: ↑Sat Jan 11, 2020 10:26 am Well, that depends.
Each symptom will pop up in the most worse situation you can ever think about. Murphy will be your passenger.
The CTM will cry for help, no roof movement anymore, the windows can't be closed, it will end in a nightmare far away from home. Special here near the alps, it will hit you on the mountains when the rain is coming up.
That is the the same with all the other maintenance tasks: battery, micro switches, looms, relais, ...
mSport 23i
- step_change
Not sure this was answered earlier but no need to isolate anything? No battery disconnect required?
Did any of you guys "pretest" the relays first in case you were replacing an old (but working) one with a duffer... ? Or am I far too paranoid...
Gone : 2013 35is, Melbourne Red, DCT, Nav, Comfort pack
Gone: 2007 2.5is, Montego Blue, Auto, Nav
- kinger
I thought we could have a joint session at your place and sort em both out at the same time RobSmartbear wrote: ↑Fri Jan 10, 2020 10:38 pmI bet you wished you’d never asked now!kinger wrote: ↑Fri Jan 10, 2020 10:36 pmGreat stuff Robbi..thanks for the advice....RobbiZ4 wrote: ↑Fri Jan 10, 2020 9:37 pm What's the age of your car?
There are two potential causes:
- broken wires in the roof
For the latter I have to check the English name.
- micro switches "Koppelverschluss" in the compartment
That is another of my 6 recommendations in the German ZRoadster forum:
replace both micro switches every 10 years.
There is a small spring on each micro switch, that is streched permanently. It gets weak over the years and leads to random states of these switches, often while driving over small bumpers or other road issues. Sometimes the switch may even "hang" and from the CTMs view, the lid is not locked.
PartNo:
54377228585 Microswitch kinematics box left Z4 (54377228585)
54377228586 Microswitch kinematics box right Z4 (54377228586)
https://www.newtis.info/tisv2/a/en/e89- ... 1VnY72z6aT
Takes about one hour to replace both - once you have seen how to.
Mike
I almost dropped round last Sunday after being turned away from the Haynes Breakfast meeting...
Mike
Current - E89 35is Saphire Black
Previous- E89 35i Space Grey
- step_change
Robbi, you could get yourself a nice little business going by coming over for a week with a solid set of bookings and update everyone's roof with all these "consumable" parts for a set fee?
- RobbiZ4
If the circle of prices owners were willing to pay vs reasonable remuneration for RobbiZ4 could be squared I’d be in..step_change wrote: ↑Sat Jan 11, 2020 11:34 am Robbi, you could get yourself a nice little business going by coming over for a week with a solid set of bookings and update everyone's roof with all these "consumable" parts for a set fee?
- scootr
Micro switches ordered ~ Thank you for the information.
E89 3.0L 6 MT gone
Michelin P4s
Bilstein struts & shocks
Luxon tower brace
Michelin P4s
Luxon tower brace
- RobbiZ4
- scootr
I see. Time to hang out your shingle then and let them come to you. OR open an internet store selling parts with unique instructions and tech support. That can be very lucrative and you can do it from home in your bunny slippers
E89 3.0L 6 MT gone
Michelin P4s
Luxon tower brace
Michelin P4s
Luxon tower brace
- kinger
Im only 12 miles from Rob /Smartbear...count me inRobbiZ4 wrote: ↑Sat Jan 11, 2020 1:29 pmYeah, but its a bit more complicated:
E89 are rare in UK, a warm and dry xxl-garage with power supply is required to replace/repair critical or broken components. Driving around is not the main problem.
Munich - Edinburgh is about 1.800 km
Munich - Smartbear-City is about 1.400 km
Combined about 2.100 km one way.
But - my daily E61 is driving with LPG, that'll reduce driving costs.
- kinger
Robbi, was spot on with this diagnosis of my car, he really is extremely knowledeable and very helpful.RobbiZ4 wrote: ↑Sat Jan 11, 2020 10:26 amWell, that depends.tintoverano wrote: ↑Sat Jan 11, 2020 9:20 am couldn't replacing the micro switches wait till they start producing the symptom?
The CTM will cry for help, no roof movement anymore, the windows can't be closed, it will end in a nightmare far away from home. Special here near the alps, it will hit you in the mountains when the rain is coming up.
That is the same with all the other maintenance tasks: battery, micro switches, looms, relais, ...
My roof went from giving very random warnings of 'Roof Movement Impaired' to even more infrequent 'Roof not Latched' ones
this then turned to very frequent to almost constant bongs / warnings and red lights on the switch
Eventually i couldnt move my roof at all ...
On Tuesday i took the car to Cayman Auto in Redhill and they were superb, they diagnosed a failed switch on the nearside, replaced it,had me on the road back home in 3 hours.
The cost of al this is circa £500 including parts & labour and is garanteed for a 1 year.
Luckily when they were inspecting the car they informed me the drivers side had already been changed, so fingers crossed no microswitch problems for me for 8 or 9 years.
My advice would be to change those switches while you can still put your roof into a suitable position to do so.
The parts are about £20-£25 per side...
Huge thanks to Robbi for all his help and advice, thanks to Smartbear for coffee and help and a Massive thank you to Cayman for fixing my car.
Mike
- tintoverano
did the change, here're the shots of the two replaced relays
I guess these contact pins don't look that bad, but not clear neither
the car is 8 years old - probably the previous owner didn't open the roof that much
- IMG_20200213_150837.jpg (114.85 KiB) Viewed 1176 times
- IMG_20200213_150746.jpg (158.72 KiB) Viewed 1176 times
- IMG_20200213_150629.jpg (144.93 KiB) Viewed 1176 times
- IMG_20200213_150523.jpg (97.68 KiB) Viewed 1176 times
mSport 23i
