Aircon auto ?
Aircon auto ?
When i press auto on then set temp about 23 degree all is good.
But if i do the same with aircon on it blows cold.
I would have thought the aircon would not blow cold unless the car inside is hotter than set temp ?
I needed aircon to keep windows clear today in heavy rain but the aircon was blowing cold outside 15 degree inside set at 23 ?
So i winter if you use aircon to clear windows it blows cold ?
- R60BBA
Aircon auto ?
I believe in all BMWs, if you have the climate control selected to Auto, but then turn on the AC; the AC will override the Auto function.
Having said that I’ve never felt the need to turn on AC if my Auto is set to 20 or above.
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
Aircon auto ?
I wanted it on to keep the windows from misting up in heavy rain
Aircon auto ?
I have mine on auto (& AC on) all the time. Set the temperature and forget it. If it's blowing a bit cold, use the red/blue thumbwheel next to the vents to 'fine tune' the air that's blowing at face vent level. Works a treat!
10-plate E89 35i, Deep Sea Blue
67-plate F15 X5 35d, Space Grey
Aircon auto ?
As far as Auto is concerned, my understanding is that this is where the air blows and how fast - the temp (& AC) settings determine the temp that it blows at.
- Jembo
Aircon auto ?
There is a seal around the Aircon pump than is very likely to dry out if not regularly lubricated... & then the Aircon will slowly deteriorate.
Generally accepted wisdom (in a Tintop) is to leave the climate function on all year round, both for lubrication & to clear dampness as mentioned above during winter months... even if it does mean using a little more fuel
Lifer 54
Lifer 54
Aircon auto ?
Not true, In my old E46 and my current 2016 F20 1 series you just set the temperature leave it on auto with A/C on it regulates the temperature automatically. However in my 2009 Z4 I find it working the same as the OP and I have to turn it up all the way to around 26 to 28º to get the temp to what should be around 22º, not sure if there is some kind of fault. On another note it is recommendable to use the air con at least once or twice each month otherwise the seals will dry out and the air con will cause problems.
Aircon auto ?
Thanks silverstar.
So that red blue dial on dash is seporate to auto temp.
Aircon auto ?
Just used in wifes fiat 500.
With the heater set to medium ish and aircon on it blows out heated conditioned air.
To warm car and stops windows fogging up like you need in winter.
But in z4 it blows out cold conditioned air with temp set to 23 outside 16.
I will try setting at 26 in that situation.
Still sussing what that dial in centre of vents does in relation to auto temp setting.
- Tinker15
Aircon auto ?
According to the manual the dial between the centre vents is: “Thumbwheel for adjusting the amount of
cool air from the vents to the upper body area. This can be used to adjust the air temperature for the upper body area.”
However, my E89 has the same problem as others on this thread. Unless I turn the temperature to maximum in air coming out of the vents feels cool and I can hardly say it is hot on maximum. When it was in my Indy for a service I asked him to check it and he could find nothing wrong with it! On the other hand I am now in France where temperatures have been very high and the air conditioning works very well with top up or down. I did have the gas replaced before I left the UK.
Aircon auto ?
Yes correct it is separate to auto setting and it is to regulate how much hot or cold air comes out of the face level vents. I used it mainly in the winter (when I was in the UK) when you'd have the heating on full (e.g to the feet) but you wanted a slightly cooler air to the face / head level.Spawny lad wrote: ↑Sun Jul 28, 2019 12:09 pm Thanks silverstar.
I didn't think about it but I suppose you can use it the other way around and set it to warmer air flow for the face level vents with the air con on and auto temp set to 20 or 22º. I'll try it out when I am next in the car.
Aircon auto ?
Strange to me with a bmw that you dont just set temp.put aircon on press auto .
You put aircon on and thats goes out the window and you just get cold with no temp control.
My other cars with climate did,nt work like that.
Aircon auto ?
I just set auto (with ac) and the temperature I want. Seems to work fine. Perhaps a problem with yours.
Aircon auto ?
Yes maybe .
Not sure
Not sure
Aircon auto ?
I think The red/blue thumbwheel works the same as in my old E39.
In the red position it just obeys the auto temp setting on the master dial; however, the blue setting allows you to manually override the system and get a blast of cool air in your face. I think the idea is that if your on a long drive or feeling a bit tired it's a good idea to blast yourself with a bit of cool air instantly with just the flick of the wheel. I leave mine in the red unless I feel stuffy and need the instant cold air.
E89 30i 2009
