Yep, I had them on my 35isgadgetJunky72 wrote: ↑Sat Jun 08, 2019 9:35 am Height looks perfect.
Can I use these springs on a car with adaptive suspension?
New springs
- sunnydays
New springs
New springs
Has the Eibach springs affected the ride quality?Jollyjoiner wrote: ↑Fri Jun 07, 2019 10:57 am Well I finally managed to get the new front brake discs and pads on and also the cars Eibach pro springs which make it 20mm front 10mm rear lower. Happy with the height now. I've also ordered some wheel spacers, 10mm rear 5mm front.
These wheels will stay on until the tyres are getting ready, then I'll swap them.20190607_101757.jpg
New springs
10mm and 5mm would mean you won't be running a hub centric setup.
However, with 12mm and 3mm you will.
Just thought I'd let you know.
New springs
I can tell you that going from m sport suspension to eibachs (19" wheels), the ride is definitely better due to the progressive springs and the m sport springs being so stiff to begin with.Silverstar wrote: ↑Fri Jul 05, 2019 9:46 pmHas the Eibach springs affected the ride quality?Jollyjoiner wrote: ↑Fri Jun 07, 2019 10:57 am Well I finally managed to get the new front brake discs and pads on and also the cars Eibach pro springs which make it 20mm front 10mm rear lower. Happy with the height now. I've also ordered some wheel spacers, 10mm rear 5mm front.
- Jollyjoiner
New springs
Ride quality is just as before which was fineSilverstar wrote: ↑Fri Jul 05, 2019 9:46 pmHas the Eibach springs affected the ride quality?Jollyjoiner wrote: ↑Fri Jun 07, 2019 10:57 am Well I finally managed to get the new front brake discs and pads on and also the cars Eibach pro springs which make it 20mm front 10mm rear lower. Happy with the height now. I've also ordered some wheel spacers, 10mm rear 5mm front.
2009 35i DCT silver
SLT mapped to 365bhp
- Jollyjoiner
New springs
I only scrape on the odd speed bump, mainly the odd single one that seems to be sticking up more than the others.
2009 35i DCT silver
- Jollyjoiner
New springs
10mm rears are hub centric but your right the fronts on 5's are not but it's still got all 5 bolts in so will be fine
2009 35i DCT silver
New springs
No, pretty certain 10mm is not hubcentric.. but yes, 5 bolts soJollyjoiner wrote: ↑Sun Jul 07, 2019 8:09 pm10mm rears are hub centric but your right the fronts on 5's are not but it's still got all 5 bolts in so will be fine
- Jollyjoiner
New springs
Nope they are, I should know I put them on myself. 10mm spacer with two machined faces, one to go over the hub lip and then the lip on the face for the wheel to sit on.warmasice wrote: ↑Mon Jul 08, 2019 2:08 amNo, pretty certain 10mm is not hubcentric.. but yes, 5 bolts soJollyjoiner wrote: ↑Sun Jul 07, 2019 8:09 pm10mm rears are hub centric but your right the fronts on 5's are not but it's still got all 5 bolts in so will be fine
2009 35i DCT silver
- sunnydays
New springs
Not hubcentric opJollyjoiner wrote: ↑Mon Jul 08, 2019 9:17 pmNope they are, I should know I put them on myself. 10mm spacer with two machined faces, one to go over the hub lip and then the lip on the face for the wheel to sit on.warmasice wrote: ↑Mon Jul 08, 2019 2:08 amNo, pretty certain 10mm is not hubcentric.. but yes, 5 bolts soJollyjoiner wrote: ↑Sun Jul 07, 2019 8:09 pm 10mm rears are hub centric but your right the fronts on 5's are not but it's still got all 5 bolts in so will be fine
New springs
The hub lip is 10-11mm so can't even imagine how that's possible. But fair enough.Jollyjoiner wrote: ↑Mon Jul 08, 2019 9:17 pmNope they are, I should know I put them on myself. 10mm spacer with two machined faces, one to go over the hub lip and then the lip on the face for the wheel to sit on.warmasice wrote: ↑Mon Jul 08, 2019 2:08 amNo, pretty certain 10mm is not hubcentric.. but yes, 5 bolts soJollyjoiner wrote: ↑Sun Jul 07, 2019 8:09 pm 10mm rears are hub centric but your right the fronts on 5's are not but it's still got all 5 bolts in so will be fine
- Jollyjoiner
New springs
2009 35i DCT silver
New springs
I am also thinking of fitting set of Eibach Pro springs to reduce the ride height a bit. I was advised to go 12mm and 15mm hubcentric Spacers. ( but I did say I wanted a more Flush with wings look)
Are you happy with the Spacers sizes you mention OP, or wish you had gone bigger ?
E89 35iS
- Jollyjoiner
New springs
No I'm happy with what it went with, and no rubbing.Mavster wrote: ↑Wed Sep 11, 2019 10:00 am I am also thinking of fitting set of Eibach Pro springs to reduce the ride height a bit. I was advised to go 12mm and 15mm hubcentric Spacers. ( but I did say I wanted a more Flush with wings look)
At some stage I will be swapping the wheels but I'll still be going for as close as the stance it has now
2009 35i DCT silver
