phone dock remove
- tintoverano
phone dock remove
hi,
how to remove the dock, there must be screws underneath, because I can't lift the center console
cheers
cheers
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
phone dock remove
you need to get a trim removal tool right at the front and force it up. the inner plastic bit (with the white arrow on) does not come off.
just keep trying. it takes a bit of force and you have to get the spot just right. once the front is prised free starting round the side to pry the rest of it off.
- tintoverano
phone dock remove
do you mean to force the phone cradle up only or the whole console with the cupholders?
thanks
thanks
mSport 23i
phone dock remove
Phone cradle only. There will be 2 more screws underneath it. Once you take them out the whole tray will come out.
- tintoverano
phone dock remove
I see, OK - thanks
mSport 23i
- Nictrix
phone dock remove
As Gadget Junky says there are 2 screws under the phone holder and its held in tight.
From what I remember there are between 6 and 8 one way clips that hold it in.
I think the other option other than forcing it out with trim tools would be removing the whole centre console and releasing the clips from underneath.
- tintoverano
phone dock remove
I'll give another try the cradle tomorrow - had to watch Liverpool
mSport 23i
- red_35is
phone dock remove
I need that drinks holder tray! But I have one half plain tray other half phone cradle like pictured. Let us know if you can get it out without breaking anything, and the part number, will be under the tray. Thanks.
- tintoverano
phone dock remove
will do
mSport 23i
- red_35is
phone dock remove
- Nictrix
phone dock remove
When you get the phone cradle out, there is a rubber mat available from BMW to fit the space thats left.
- Stuartt
phone dock remove
All the part numbers are on realoem and the different inserts available.
Stuart
2004 3.0i SE Roadster , GONE to a good home
2010 e89 35i Sdrive M sport. GONE for salvage but has been reborn
2014 e89 35is M-Sport Design Pure Traction
phone dock remove
I have exactly the same in mine, cup holders and phone module. If anyone has the empty storage space and wants mine, then Iβm happy to swap if itβs a simple thing to do (I havenβt tried). I am fed up with the lack of space and never use the cup holders.
Z4 S-Drive 35i
Audi TT S-line
Mazda MX5 Mk2.5 (for sale)
Wokingham Berkshire
Audi TT S-line
Wokingham Berkshire
- tintoverano
phone dock remove
okay, I'll do the remove in the evening and report
mSport 23i
- red_35is
phone dock remove
maybe a couple of useful links
https://e89.zpost.com/forums/showthread.php?t=849397
https://e89.zpost.com/forums/showthread.php?t=586164
