If you presented an illegal mix such as cross ply & radials on the same axle they would fail the car.road warrior wrote: ↑Fri Apr 26, 2019 1:46 pmim not sure tyre spec is part of an mot above tread depth and damaged sidewallsSmartbear wrote: ↑Fri Apr 26, 2019 9:52 amMy car passed an MOT with that set up, so it was road legalJembo wrote: ↑Fri Apr 26, 2019 7:52 am
For much of the time as many say won’t notice much difference - they’re both a round bit of rubber.
It’s the 5% when all hell breaks loose - Personally, I spend money on the same high quality tyres for the point RW mentions, they’re dynamically different & in an emergency won’t be consistent.
It’s a personal preference, where knowing you’re relying on only 4 small bits of rubber the size of your hand I want this area to perform as best as physically possible in those extreme emergency stress situations.
I suppose it also comes down to the view an insurer would take were you to be involved in an accident.
I don’t think it’s illegal to run runflats & non rf tyres front/rear
