New front & rear brake discs & pads, parts & labour, on 35iS, by Sytner
Parts
£67.69 Front pads
£14.21 Sensors
£0.84 Plastilube
£202.09 Discs
£1.28 Disc bolts
£51.89 Rear pads
£14.93 Sensors
£1.40 Plastilube
£96.87 Discs
£1.28 Disc bolts
£2.59 "Safety clnr"[?]
£10.10 Brake fluid
£198.01 Labour
Plus VAT, of course.
Parts
£67.69 Front pads
£14.21 Sensors
£0.84 Plastilube
£202.09 Discs
£1.28 Disc bolts
£51.89 Rear pads
£14.93 Sensors
£1.40 Plastilube
£96.87 Discs
£1.28 Disc bolts
£10.10 Brake fluid
£198.01 Labour
Vidi, vici, veni
Busterboo, you made me get my calculator out! I assume that was for 1 hour of Labour
Amazing that the main dealer is so tight they charge for lube with that labour rate! You would think workshop sundries would be included.
On the bright side you will now have less money to spend on easter eggs which is good for your health.
- ronk
Only £202 for a pair of disks?
My total bill at an Indy for fronts only on the 335 was £640
I hope you gave them a tip for being so reasonable I mean £198 for labour. That's hardly enough to cover their tea break.
Yep, I checked with my local indy and, for this job, Sytner were cheaper.
Vidi, vici, veni
- R.E92
Was that about £800 inc VAT in total?
Not bad for dealership work
I paid £490 for just the fronts, so seems about right. Those discs are a bugger aren’t they, bloody dustbin lids.
Pure Traction 35iS - Sold!
Carbon Black E86 3.0si Coupe - Gone but not forgotten
- ronk
I paid £640 for the front brakes (370mm) on the 335 - at an Indy - BMW wanted £850 ish for the job.
I think you’ve got a bargain - I’ve just checked with Europarts online and their discs are circa £220 each for the 35is and of course only sold as a pair ! So discs front only would have been £440.
Your £202 is a comparative bargain even after you add the vat :
I suspect somebody in the parts dept has dropped a bollock!
Ps - if the price is correct i will travel south to have mine done when they need it.
It really isn’t hard to do this yourself and it’s quite satisfying when you’ve down the work yourself! Save half that cost as well...
- Beatman
+1Angelus666 wrote: ↑Mon Apr 22, 2019 9:15 pm It really isn’t hard to do this yourself and it’s quite satisfying when you’ve down the work yourself! Save half that cost as well...
My Car- 2004 3.0se sterling grey, mv3s , satnav, heated seats, ZHP.
- ronk
I know - I used to do all my own work but a neck / spinal problem prevents that activity these days - it goes against the grain to pay money for such a simple job that I used to do without thinking,Angelus666 wrote: ↑Mon Apr 22, 2019 9:15 pm It really isn’t hard to do this yourself and it’s quite satisfying when you’ve down the work yourself! Save half that cost as well...
I should really get rid of a lot of tools , ie the ramps /axle stand type of stuff.
Not half the cost, but only the labour ... also I don't have the facilities/tools to do the job ... and, anyway, it would ruin my nails.Angelus666 wrote: ↑Mon Apr 22, 2019 9:15 pm It really isn’t hard to do this yourself and it’s quite satisfying when you’ve down the work yourself! Save half that cost as well...
Vidi, vici, veni
Before going to Sytner's, I checked with a well-known local indy and, for the fronts, he wanted £330 + VAT.ronk wrote: ↑Mon Apr 22, 2019 11:27 am I paid £640 for the front brakes (370mm) on the 335 - at an Indy - BMW wanted £850 ish for the job.
Vidi, vici, veni
