Android Dash Display Screen
AnubisZed
Post by AnubisZed » Wed Jul 03, 2019 10:19 pm
I'm testing the update as we speak, so hopefully I'll have good news tomorrow, but it did glitch earlier so I'm not prepared to let it go out just yet, sorry.
Dave
2011, 23i, Grey with Red leather. 8)
E89 Cruise Control "How-To">> viewtopic.php?f=46&t=107989
E89 Cruise Control Fitting Service >> viewtopic.php?f=13&t=116957
scottp3000
Post by scottp3000 » Thu Jul 04, 2019 8:19 am
Cheers again Dave, supremely helpful! :)
I'll give it another shot over the weekend.
Just in case it helps anyone else - i've attached a 128gb portable USB drive stacked with music to the USB extension cables (located mine in glovebox), and it works a treat. Slight pause on selecting music while it finds the drive when you open the app, but otherwise magic :)
AnubisZed
Post by AnubisZed » Fri Jul 05, 2019 5:39 pm
UPDATE:- Ok as for the ID7 UI update, I am not prepared to offer this to anyone at this moment in time due to it being "buggy"
Hopefully a new full version will be available in a couple of weeks, sorry but I don't want to be bombarded by "why this" and "how that", so I'll let you have it once the new release is proved to work properly from the install without tweaks.
Dave
vld
Post by vld » Thu Aug 22, 2019 1:36 pm
The GPS on my unit crapped out.
Given that the "company" behind this product never answered any of my emails, I'm assuming I'm s**t out of luck.
(Sweden) E89 2012 20i Melbourne Red, Smart-top, Android display, 2.8i mapped, Retrofitted: cup holder and cruise control
vld
Post by vld » Thu Aug 22, 2019 9:52 pm
I think I managed to fix it, not sure if it works as good as originally though as it still seem to hiccup.
I've installed the app "GPS Test", and from its menu you choose "AGPS" -> "Clear and update". Not sure exactly what this does, clearing some cache perhaps. Before doing this it was just dead, showing that it sees just one satellite or none at all, regardless of how long I was waiting, regardless of reboots or factory resets in the custom settings page (i haven't factory reset whole Android as I didn't want to spend time reinstalling and reconfiguring everything).
One thing to note: do not set the Android location mode to "High accuracy". For me at least, that is only making it work erratically or not at all. "GPS only" is the only option that works for me (regardless if the unit has Internet access or not).
LordLolzeye
Post by LordLolzeye » Fri Aug 23, 2019 6:24 am
Anyone experienced audio issue with the new unit? I've recently bought an wireless carplay unit that i've connected via USB, since then, the unit decided the audio is not necesarry anymore and stopped working. Any ideeas? (I'll probably start by removing the carplay unit, if that doesn't work - factory reset)
vld
Post by vld » Fri Sep 06, 2019 7:31 pm
- If music wasn't ever started during the driving session, the GPS navigation or Bluetooth only goes into the left speaker with loud and crackling sound. The solution for me is to play a song for a second.
vld
Post by vld » Fri Sep 06, 2019 11:04 pm
About my GPS problem, I finally factory reset Android and it seems to have solved the problem. So hopefully it wasn't a hardware issue, but just some app that messed up settings, or maybe I did something wrong.
Moreover, I made it even better than before. I found an awesome app called "GPS Keeper", which keeps the GPS lock from going cold. That means, if you stop your navigation app and reopen it at a later time, after you drive for a while, there won't be any delays anymore. I am using the pro version, which allows it to run at boot time. That means, if I leave home and on my way I decide that I need some guidance, the nav app will instantly have my location, no more waiting for the GPS to find the fix.
Some other change that considerably improved my experience, was to add the GBoard app, for a proper keyboard app which is easier to type in (addresses for example, in the nav app).
I complained before about brightness, at night. I have finally found the brightness control option, it's hidden under "Camera/Video Settings" (for some reason). On top of that, I just realized that I can use the power icon on the top right corner to turn the screen off completely (not sure how I missed it until now :P).
One thing that bugged me was the fact that the Bluetooth options were missing from the Android settings, so you can't connect other devices to it. I now learned that the reason for this is that the unit uses a custom Bluetooth module, to enable the device to act as a sound receiver from your phone. And I think I might be able to use an USB Bluetooth dongle to add the functionality one has on a regular phone/tablet.
A tip for those that are going to install the unit: sound proof the plastic around the unit (not sure how, tape, grease or whatever) because it can make a lot of annoying squeaky noise on less than perfect asphalt. Listening to music covers the noise, but without the music it bugs me enough to wanting to redo the install.
So, after three months of using the device, would I buy it again? Yes, I would.
Adil_3
Post by Adil_3 » Sat Sep 07, 2019 12:32 pm
right so im kinda in the market for one, the price is pretty steep considering. Anyone got any used ones or a sensible price up for sale of these bad boys !
AnubisZed
Post by AnubisZed » Mon Sep 09, 2019 8:03 am
vld - I'm glad you are sorting problems with it (did you edit that last post? I'm sure you originally said something different!). As for brightness you can swipe down the screen twice to reveal a brightness control (or you could in the original version, I'm currently running the updated software with the new ID7 UI and haven't looked recently).
To be fair I'm not using my unit to it's fullest advantage as I run everything through Android Auto (Headunit Reloaded app), so that's my music, sat-nav, phone etc, but then the screen is there if I don't have a good enough phone signal as I have sat-nav on-board (Sygic) and music on my memory card. Yes the GPS receiver is slow to pick up so I might have a look at that "GPS Keeper" and see how it goes.
Dave
AnubisZed
Post by AnubisZed » Mon Sep 09, 2019 8:07 am
You could try Aliexpress, and you want to be looking for Android 9, with 4GB RAM and either 6 or 8 core processor to have the latest version. Also if you want the iDrive rotary controller then make sure it's an option as most don't sell it with it. :thumbsup:
There is a company in Germany that sell through eBay but as the price is well over £1000 it's just not worth it. :headbang:
Dave
vld
Post by vld » Mon Sep 09, 2019 4:18 pm
hehe, yeah, it was a post full of ranting, i cooled off and spent a couple of hours in the car trying to solve my issues, and edited the post on a positive tone :)
I did use this combo for a few weeks, and while it worked fine, it was a bit annoying that it wasn't full screen. With the latest versions of AA and HUR (updated via the XDA Labs app) it is now full screen and better than ever. I still decided to install AA directly on the unit and using my phone just for the Internet connection. It is a bit smoother and it starts considerably faster.
I still have a bit of trouble with the WiFi, which doesn't always want to autoconnect to my phone's hotspot or sometimes it takes a long time before it decides to connect. But given that I have offline maps downloaded in Google Maps, it's not particularly a problem. I try to keep the device as useful as possible in an offline mode.
Other good use I found for it: Audible/Youtube/Ted for audio books, lectures and other talks. Not watching the screen while I drive, just listening. Makes commuting more fun.
vld
Post by vld » Sun Sep 15, 2019 11:23 pm
I found the problem with my GPS signal. Turns out it's a bad idea to install the GPS antenna under the center speaker cover. That cover is a metallic mesh and it shields the antenna too much. From a cold GPS start (*), it took up to 10 minutes to get a location fix. From a warm start (**) at least 5 minutes. After removing the cover, the warm start now takes a minute or even less. So i will have to find a new location for the antenna, probably directly on the dashboard.
* A "cold" GPS start refers to a situation in which the GPS device must acquire all data in order to start navigation, like if the device is brand new or has recently been factory reset. This usually happens when you haven't used the car in a while.
** A "warm" or "normal" start means the GPS has most of the data it needs in memory and will start quickly. A warm start happens when the device has been off for a day or so, but not off so long that its data is extremely outdated.
Edit: people using similar devices and posting about it on other forums report that they get a considerably better GPS fix once they either replace the GPS antenna with another one, or use the BMW original antenna (if the car has original nav) with a splitter.
R.E92
Post by R.E92 » Mon Sep 16, 2019 10:54 am
Look into installing a version of the youtube app called "Vanced". https://www.xda-developers.com/youtube-vanced-apk/
It'll let you play content while youtube is in the background and also offers a picture-in-picture mode. Otherwise you might get ticketed for having video playing while driving.
bmw665
Post by bmw665 » Tue Sep 17, 2019 2:20 am
After 9 pages of dialog, it sounds like many of you have found the issues but still seem positive. For all of us sideline readers, would you recommend it? Looking at the videos, there are a few things it doesn't do if you don't have iDrive
