2011 E89 paddle shift update
Busterboo
Post by Busterboo » Sat Feb 02, 2019 12:02 am
ronk wrote: Fri Feb 01, 2019 6:30 pm sounds like rubbing ya belly and patting ya head! :D
"I use the right paddle (up & down)" so your car has the two option paddles?
Yep, both left & right paddles change gear up and down.
It's more practical than the 'left paddle down/right paddle up' I had on a 911.
Vidi, vici, veni
ronk
Post by ronk » Sat Feb 02, 2019 12:44 am
When I had that system I seem to remember only using the RH paddle for both up and down.
Busterboo
Post by Busterboo » Sat Feb 02, 2019 2:40 am
Yep, it works very well.
Vidi, vici, veni
enzed4
Post by enzed4 » Sat Feb 02, 2019 4:36 am
ronk wrote: Sat Feb 02, 2019 12:44 am When I had that system I seem to remember only using the RH paddle for both up and down.
Pretty much what I do as well :thumbsup:
I don't understand why you would want to change the older style for new ones? If you have the older ones, then you can choose to use only one side for up and the other side for down, because both sides will do either. Why remove a feature and lock in only one option? Unless you're worried about accidentally shifting up instead of down or vice versa?
And as was posted earlier in this thread, I believe the older style can be coded to only work up or down on either side as well?
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
ronk
Post by ronk » Sat Feb 02, 2019 12:33 pm
The bottom line is they’re a bit of a gimmick!
