did anybody install HD-LINK IW04B-N video interface?
- tintoverano
hello Guys,
I hope somebody managed to install this before https://car-solutions.com/en/video-inte ... elines.php
they write that it may not work for z4 e89, but in the comments they say it works
I guess it should as the CIC specs are the same as for the e90, right?
thanks,
tinto
thanks,
tinto
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
- tintoverano
got a reply from the vendor: "This video interface may work with E89 but CAN wires should be connected separately because the connector is different. Unfortunately, we don't have pinout of E89 connector that goes to the monitor."
connecting shouldn't be a problem, but how to figure out if the video worked
so far this seems to be the cheapest solution out there putting Android on the screen
mSport 23i
Dave
2011, 23i, Grey with Red leather.
And yes your thinking is correct, the wiring and units used in the e89 are the same as the e90 etc
The difference is the actual screen, but the connectivity is the same.
Dave
- tintoverano
whoa, that's great news
thank you for the update!!
mSport 23i
This may help you more though...
https://www.newtis.info/tisv2/a/en/e89- ... y/INAlGSNc
This is the connection diagram for the screen. It looks like you have all the correct connections, I'm not sure if the plug is the same though
HTH
HTH
Dave
Just checked, the plug is different, but as it's only 4 wires then this could be adapted with the right plug
Dave
- tintoverano
lovely, thanks again!!
mSport 23i
- tintoverano
AnubisZed, hi
I'm new to this kind of modding, where do I look to connect these 4 CAN wires mentioned above, which are not pinout by the vendor? thanks
mSport 23i
If you look at the manual (in your first post), page 6 top right corner it gives you the positions of the wires in relation to the e90 plug;tintoverano wrote: ↑Wed Apr 03, 2019 12:18 pm AnubisZed, hi
Pin 1 = red/Yellow, power
Pin 3 = brown, ground
Pin 5 = light green/orange, can high
Pin 6 = light green, can low
Then if you go to post 6 above it takes you to the e89 pin out page and shows you on the left of the page;
Pin 1 = red/yellow, power
Pin 2 = brown/black, ground
Pin 3 = orange/green, can high
Pin 4 = green, can low
So from that you can determine which wires go where.
The problem will be that the input socket on the HDMI unit will be for the plug type of the e90 but you could get hold of a blank one for this and use it to replace your current e89 (4 pin) plug. And the plug from the HDMI unit output will be for the e90, but here you could use the e89 plug you're taking off from the stage above (if that makes sense) then it'll plug into your e89 pop-up screen socket.
Dave
- tintoverano
thanks a lot Dave, I'm getting it now
mSport 23i
- tintoverano
I found a post https://www.m3post.com/forums/showthread.php?t=780402 where the part number is cited: 61136954526AnubisZed wrote: ↑Wed Apr 03, 2019 1:12 pm The problem will be that the input socket on the HDMI unit will be for the plug type of the e90 but you could get hold of a blank one for this and use it to replace your current e89 (4 pin) plug. And the plug from the HDMI unit output will be for the e90, but here you could use the e89 plug you're taking off from the stage above (if that makes sense) then it'll plug into your e89 pop-up screen socket.
realoem is telling that it is the same for e89 http://www.realoem.com/bmw/enUS/partxre ... 1136954526
am I looking at the right thing?
thanks
mSport 23i
Yes bud that looks like the right plugtintoverano wrote: ↑Thu Apr 04, 2019 12:28 pmI found a post https://www.m3post.com/forums/showthread.php?t=780402 where the part number is cited: 61136954526AnubisZed wrote: ↑Wed Apr 03, 2019 1:12 pm The problem will be that the input socket on the HDMI unit will be for the plug type of the e90 but you could get hold of a blank one for this and use it to replace your current e89 (4 pin) plug. And the plug from the HDMI unit output will be for the e90, but here you could use the e89 plug you're taking off from the stage above (if that makes sense) then it'll plug into your e89 pop-up screen socket.
thanks
Dave
- tintoverano
AnubisZed, this part 61136954526 doesn't seem right, I couldn't find 8-pin ones on realoem.com http://www.realoem.com/bmw/enUS/partgrp ... _23i&mg=61
what do you think?
what do you think?
mSport 23i
If you put that part number into the Part Number search box it will come up with the plug for an 8 pol version, don't bother trying to find it on the specific car page as you won't find it.tintoverano wrote: ↑Thu Apr 25, 2019 1:08 pm AnubisZed, this part 61136954526 doesn't seem right, I couldn't find 8-pin ones on realoem.com http://www.realoem.com/bmw/enUS/partgrp ... _23i&mg=61
what do you think?
Dave
