I guess you either accept that Yuasa, Varta, BMW, Mercedes et all, plus loads of independents say you should, or go your own way..nice article here that clearly explains coding vs registrationph001 wrote: ↑Tue Jan 22, 2019 5:38 pm ...and how do you suppose the car knows the state of charge of the battery when it is first fitted?? Bearing in mind they are often sat on a shelf for 6 months in a stock room. Same when people connect a charger directly across the battery, bypassing the IBS module.
I'm not going to go into the technicalities of all this again as you can read it all on my other posts on the subject, suffice to say all the calculations are done through LIVE data measurements by the IBS module. It all sorts itself out after a few charge / discharge cycles.
https://www.youcanic.com/guide/bmw-battery-registration
