Rough idle and injector cleaner
OnlineNictrix
It does make you wonder especially when there are companies that recondition injectors.
Maybe all they do is clean them.
- R.E92
When mine failed they got stuck open and fuel was pouring out of the exhaust pipe.Gaffa22 wrote: ↑Mon Jan 14, 2019 12:53 pm Well it does make you wonder how many injectors have been replaced that just needed a clean
I am absolutely certain my injectors were leaking which is what can cause the rough idle, as the spark plugs get wet because of the excess fuel in the cylinder.
Admittedly mine were not leaking too bad, as it only ran rough if stood for more than two weeks.
But I am also convinced that either the premium fuel or the additives, or a combination of the two, cleaned what ever deposits were causing the leaks
In which case I believe its definitely beneficial to run our cars on premium fuels
- Gaffa22
Does anyone actually recon the BMW Direct injectors though ?
R.E92 they were properly f**ked then did it melt the cats ?
2010 E89 35i DCT
2017 Honda CBR1000RR fireblade
2016 Honda VFR1200F
2016 Honda VFR1200F
- R.E92
I don't think so but the warranty rectification involved 12* new injectors, 6 new plugs, 4 new cats and 4 new O2 sensors.
They replaced most of that trying to chase down a problem with a misfire which turned out to be caused by them not installing the decoupling elements on the injector. So they had to replace the injectors twice.
- Gaffa22
Ah yes I remember you having problems
If you get neat fuel in the cats they are knackered so a bloody good job you were under warranty as I bet it came to lots of £ the injectors are over £1200 a set
2010 E89 35i DCT
2016 Honda VFR1200F
2016 Honda VFR1200F
- R.E92
Just had 6 new plugs fitted and three of the old ones from one bank were pretty coked up. Still think the old girl is running a little rough but not so much as anyone not driving her regular would notice.
Use Shell v power fuel and just wondering if an additive may help to clean out possible fuel injector issues.
Any thoughts and recommendations re product would be appreciated
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- Stevo1987
Hmm...additives. All smoke and mirrors in my opinion. Marketing hogwash.Nanu wrote: ↑Thu Sep 10, 2020 7:48 pm Just had 6 new plugs fitted and three of the old ones from one bank were pretty coked up. Still think the old girl is running a little rough but not so much as anyone not driving her regular would notice.
2014 Z4 e89 35is in mineral grey.
2012 Audi TTS in Ibis white.
- Gaffa22
As per first post
I used 2 bottles / tank fulls of Techron injector cleaner then every tank I used Lucas injector cleaner / lubricant
Also look at the Archoil products
2010 E89 35i DCT
2016 Honda VFR1200F
2016 Honda VFR1200F
Techron PEA Concentrate Plus Petrol Fuel Injector System Cleaner
I assume this is the one you used? Looked it up on amazon and several places are out of stock but will find one and give it a try.
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- Gaffa22
yes that's the one
then followed it up with this in every tank full
as its a lubricant I think it helps the injector seals
It deffo cured the issues I had experienced
https://www.ebay.co.uk/i/391923263464?c ... dFEALw_wcB
2010 E89 35i DCT
2016 Honda VFR1200F
2016 Honda VFR1200F
Thanks, will try the Techron stuff first and see what happens
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
I pop a bottle of injector cleaner into every last 25% of fuel in each tankful. That way they get a nice soak in a strong solution while the car is parked.
As for snake oil, well there are regulations preventing false claims on advertising in the UK so it must do something.
Might be worth doing the old google shuffle for test results if you think its that interesting...
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- ph001
At £16 a bottle not sure I will go that far but will give it a go and see if it makes any difference. From the research I have done one every 3,000 miles appears to be the norm.mcbutler wrote: ↑Sat Sep 12, 2020 8:20 pm I pop a bottle of injector cleaner into every last 25% of fuel in each tankful. That way they get a nice soak in a strong solution while the car is parked.
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
