Radio Question.
Radio Question.
Hi.
With the Z4 2ltr 2015 comes the business radio. Does this set pick up DAB or if not can it be modified to do so? I also don't find it easy to pre-programme the stations to the FM or AM bands, I'm missing the cars handbook which would probably have this info in there!
- RustyZ4
Radio Question.
I thought all the later cars have DAB, and you can use any of the 8 buttons, to program a station to, or program anything you like to
Z4 E85 3.0, gone but now with son
- SteveSmith
Radio Question.
Do you have idrive?
28i M Sport - Alpine White / Canberra Beige, 19" M359’s, H&R’s / Eibachs, BMS Stage 1 - 271bhp, Front Splitter, CF Rear Lip, Alcantara Steering Wheel and Brembo 4 pots
Radio Question.
No there's no I drive in this one its the SE model.
Radio Question.
A Business radio in a 2015????? Are you sure? Does it actually say Business on the radio?
If it is then I'd suggest ripping it out and, if you want the OEM look, then retrofit a Professional head unit with DAB built in.
If yours does say Professional on the front of it then press the Audio button and see what comes up, if it says DAB then you already have it. If not then you could retro-fit a DAB unit or you could install an add-on like the AutoDAB unit that integrates into the car and you use the steering wheel control to operate it (and displays the info on the screen).
Dave
2011, 23i, Grey with Red leather.
Radio Question.
Cheers Dave. I must check out what you said now about the name on the front, cant say i'v taken notice but this model is new to me!AnubisZed wrote: ↑Mon Jan 07, 2019 3:46 pm A Business radio in a 2015????? Are you sure? Does it actually say Business on the radio?
Radio Question.
To help you out in recognising the head units, photos of each as attached.
If all else fails, and as I've mentioned above, the AutoDAB...
https://www.youtube.com/watch?v=BPu50CbkG7Q
- Professional.jpg (47.88 KiB) Viewed 1079 times
- Business.jpg (68.82 KiB) Viewed 1079 times
Dave
Radio Question.
WOW Dave that's good of you to provide photo's.
Just popped up the garage to check and its the Professional model but I cant see DAB anywhere? So I suppose my options are to change the set or get one of those adaptors.
- Smartbear
Radio Question.
What comes up when you press the audio button?
e85 3.0si sold
Radio Question.
OK, this took a lot of finding (as I don't have DAB on mine)......
Press "AUDIO" button (top left) and it'll display this screen, either with DAB or without..
- dab.jpg (150.48 KiB) Viewed 1059 times
Dave
- Smartbear
Radio Question.
Yep, just took a pic of my professional radio after pressing the audio button Rob
e85 3.0si sold
Radio Question.
Thanks guys I will check this out tomorrow.
Radio Question.
Can you retrofit an newer professional stereo into a 2010 car? My professional radio is far from it and has nothing going for it
Radio Question.
You can, but two quick questions first;Arcade.Eyes wrote: ↑Wed Jan 09, 2019 9:11 pm Can you retrofit an newer professional stereo into a 2010 car? My professional radio is far from it and has nothing going for it
Do you have bluetooth?
Do you have a USB socket (with an AUX port next to it) in the centre console?
If you answer no to both of those then yes it's possible and relatively straight forward.
It should cost you in the region of £350, and you'll need to do a bit of coding with a laptop.
Alas I'm on my tablet at the moment but I'll post a link for you with all the info you need if you're interested.
Dave
Radio Question.
Well thanks to the advice above I checked out the Audio button and I do have the DAB option in my zed. Happy Days.
