M4 Front Brake Caliper Retrofit
- Nictrix
With the calipers from the M4 and as said normally a 380mm disc, what pads are used with the 370mm disc?
Or do the pads hang off the edge of the disc?
- Jollyjoiner
Thanks for your effort in this, some prices and lists of the correct parts to get would be great.Player 1 wrote: ↑Sat Nov 17, 2018 10:50 pm When researching I when on realoem and took part numbers off of a 2016 440i. I don't think it matters what year as long as its the 370mm discs however I can attest that 2016 works.
Likewise, any year M4 or F series M3 for the calipers, I believe the are the same calipers on the 440i however the particular ones I got hold of were from an M4 so used M4 part numbers for the pads.
I'll get in contact with some of the parts suppliers and see how much I can get them to cut prices down by too
2009 35i DCT silver
SLT mapped to 365bhp
- Jollyjoiner
Says he thats has his the same amount of time and is doing loads of mods alreadyjohn-e89 wrote: ↑Sat Nov 17, 2018 10:56 pmSettle yourself down Nigel lad.....you’ve only just bought the piggin thing....Jollyjoiner wrote: ↑Sat Nov 17, 2018 10:16 pm I'm interested in this thread. So this sounds like they bolt straight on, does the caliper need the carrier too or is it a case of old off and new straight on ? As for the discs is there a year of car they come from ? same with the Calipers ?
Might need to start myself a search for some, I bet they a tidy price though
2009 35i DCT silver
- Player 1
Good to hear! If you do it and any questions pop up, just give me a shout and I'll be happy to help
I did look into the rear brakes and I don't think there's anything that's going to swap over from other cars without fabricating adaptor brackets. If it wasn't for the electric handbrake it'd be a lot easier!
- Player 1
When I looked on realoem there were two different part numbers for the M4 pad and the 440i pad at first however closer inspection showed that one supersedes the other and there's other part numbers that supersede that. In terms of size and shape, they are both the same though and both correlate to the same numbers from manufactures such as TRW and Brembo.
- Nictrix
Just in my head if the pads are attached to the caliper and they are made for 380mm discs when you go down to 370mm discs surely there will be 5mm of pad hanging over the edge of the disc.Player 1 wrote: ↑Sun Nov 18, 2018 8:35 pmWhen I looked on realoem there were two different part numbers for the M4 pad and the 440i pad at first however closer inspection showed that one supersedes the other and there's other part numbers that supersede that. In terms of size and shape, they are both the same though and both correlate to the same numbers from manufactures such as TRW and Brembo.
Player 1 wrote: ↑Sun Nov 18, 2018 8:27 pmGood to hear! If you do it and any questions pop up, just give me a shout and I'll be happy to help
Are you on standard springs and adaptive shocks Player? I don’t really want mine lowered and want to keep the ride comfort, but at the same time take out some of the ‘jelliness’ and tighten it up as much as possible. Sounds like you’re of a similar thinking no?
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Nictrix
Nobody have any opinions on this?Nictrix wrote: ↑Sun Nov 18, 2018 9:19 pmJust in my head if the pads are attached to the caliper and they are made for 380mm discs when you go down to 370mm discs surely there will be 5mm of pad hanging over the edge of the disc.Player 1 wrote: ↑Sun Nov 18, 2018 8:35 pmWhen I looked on realoem there were two different part numbers for the M4 pad and the 440i pad at first however closer inspection showed that one supersedes the other and there's other part numbers that supersede that. In terms of size and shape, they are both the same though and both correlate to the same numbers from manufactures such as TRW and Brembo.
If I am right, after these have been fitted for thousands of miles the overhanging pad will eventually come into contact with the overhanging pad on the other side of the disc and then you will have no brakes.
5mm could be neatly ground off the outside pad edge if need be, no different to them being worn down.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Nictrix
Yep thats fair enough. This could be done but has it? They could also be ground down later if they are getting close to contact but this would need to be remembered.
It does beg the question though, why not just use 440 calipers that are made for 370mm discs.
They look the same to me, are there any performance differences?
You should be able to yes, it’s just in Players case he had calipers off an M4 so used the part number for those.Nictrix wrote: ↑Mon Nov 19, 2018 5:04 pmYep thats fair enough. This could be done but has it? They could also be ground down later if they are getting close to contact but this would need to be remembered.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Player 1
I'm not really sure what else to say other than they don't overlap the disc?Nictrix wrote: ↑Mon Nov 19, 2018 5:04 pmYep thats fair enough. This could be done but has it? They could also be ground down later if they are getting close to contact but this would need to be remembered.
I've just gone to take a look and there's definitely no overlap, I couldn't get the camera to focus between the wheel and caliper but could feel where the pad meets disc and did take a photo of the disc itself and as you can see there's a line just at the edge of the disc where the pads end.
EDIT: Thinking about this some more, I imagine the difference between the M cars and standard isn't in the caliper or pad but in the wheel carrier and how it mounts the caliper further away from the centre point of the wheel.
- Player 1
I'm on standard springs and passive dampers. I completely agree with you re lowering, been there, done that and it's more hassle than it's worth!john-e89 wrote: ↑Mon Nov 19, 2018 12:10 pm
I fitted the anti roll bars before the M3 bits, they do exactly what they say on the tin and really help with confidence more than anything. They have a minor effect on the ride over really bad surfaces but 99% of the time you won't tell.
The M3 suspension bits have no noticeable impact on ride quality at all, if anything it's better because you've just replaced worn bushes with new.
- Nictrix
Cool. You could be right if the calipers are definately the same. I would imagine then that the 380mm discs might have fitted if the carrier was changed as well.Player 1 wrote: ↑Mon Nov 19, 2018 8:54 pmI'm not really sure what else to say other than they don't overlap the disc?Nictrix wrote: ↑Mon Nov 19, 2018 5:04 pmYep thats fair enough. This could be done but has it? They could also be ground down later if they are getting close to contact but this would need to be remembered.
I only pointed this out as I wouldnt have wanted anybody to fit something that could possibly have turned out to be dangerous.
- Player 1
For sure Nictrix, now I've got a couple hundred miles on them I'm pleased to say these have worked really well indeed.
The pedal feel is much more reminiscent of the 911`s and Boxster's I've driven and are a step up in terms of outright capability over the old brakes which themselves weren't bad.
