Carly app
- Smartbear
Carly app
You just need your Wi-fi on to connect with the dongle thingy
e85 3.0si sold
- road warrior
Carly app
i have android, so how does it connect ? does the dongle talk to wifi and android ?
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
- Nick9one1
Carly app
If youre on android you need the bluetooth dongle. The Wifi dongle is for apple devices.
You can use a cheap bluetooth OBDII dongle from eBay, but not all the features will be available in the app.
Z4 35i Space Gray, Red Leather
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP
- Smartbear
Carly app
Bluetooth or Wi-fi depending if ios or Android is used Shaun
e85 3.0si sold
- enzed4
Carly app
I just remembered - when I test drove a 3.0i E89 I took the Carly app with me and ran the 'used car check' and it worked ok with the cable. So that answers my own question. Makes sense really, since all the BT dongle is doing is converting the signal from the OBD socket to BT. Using the cable cuts out the 'middle man'
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- Smartbear
Carly app
Everyday’s a school dayenzed4 wrote: ↑Tue Nov 06, 2018 7:46 amI just remembered - when I test drove a 3.0i E89 I took the Carly app with me and ran the 'used car check' and it worked ok with the cable. So that answers my own question. Makes sense really, since all the BT dongle is doing is converting the signal from the OBD socket to BT. Using the cable cuts out the 'middle man'
e85 3.0si sold
- R.E92
Carly app
The cable will work for coding and diagnostic but the developer purposely restricted the other functions like the ebrake control and transmission function to the adapter only.
The carly app has been cracked for a while now. There's versions floating around that have all features unlocked and update checks disabled so the developer is just trying to make as much money as possible on the hardware until someone works out how to remove the adapter check and people can go back to using those £2 ELM327 adapters.
- R.E92
Carly app
There's "Carista", "Bimmercode" and "Bimmergeeks Pro Tool". They are all better than Carly. Bimmercode even works with generic OBDII ELM327 adapters.
The best and cheapest solution is to learn how to use BMW Standard Tools. You need a laptop, a DCAN cable and a bit of free time.
