Wheel size performance advantages?
What performance advantages do 19" wheels have over 18"?
Vidi, vici, veni
- Player 1
The wheels themselves? Unless they're lighter than those they're replacing then the absolute square root of jack.
If you can get bigger brakes in under there however then you can stop quicker, or at least stop just as quickly for longer.
Not wheels necessarily, but different tyre profiles will affect handling according to this guy
19" are better because they cover more distance for each rotation. Also, the 326 wheels give an extra 50 bhp.. per wheel.
OnlineMr Tidy
Except they don't if you use the OEM tyre sizes, otherwise the speedo would be wrong!
But if you use run-flats you'll probably be able to damage more wheels on 19s.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
I thought lower profile was to reduce side wall flex so better grip?
But RFT total negate the need for low profile as they already ride as though they are made of wood.
Going to normal one can feel the car is more stable as the flexing allows the car to compensate for minor road irregularities.
The extra inch, so she tells me, doesn't make much difference if anything a harsher ride.
Reducing tyre flex improves steering response but loses grip. Grip comes from maximising contact patch and keeping it in contact with the tarmac and tyres with more give in them do that better. That’s the main reason non run flats are so much better than run flats.
Z4 S-Drive 35i
Audi TT S-line
Mazda MX5 Mk2.5 (for sale)
Wokingham Berkshire
Audi TT S-line
Wokingham Berkshire
Vidi, vici, veni
- Jembo
Typically 19” wheels are heavier than 18” by a noticeable margin (unlike 17/18” weight difference) - that was my experience with AUDI wheels.... which translates into less fuel efficient.
If you look at the same new car with different wheel sizes, the CO2 emissions are different & am sure it has to do with this
Lifer 54
Lifer 54
- Valor1
If you research wheels, like HRE and some BMW wheels, you can find lightweight 19 or 20. My 20 weigh less than the OEM 19.
- thumb_IMG_0038_1024.jpg (148.57 KiB) Viewed 1927 times
- Smartbear
That maybe true but surely you could find some smaller wheels which were lighter than your 20”s?
e85 3.0si sold
- sunnydays
- Nictrix
Surely they should be weighed with tyres fitted to find out a true difference.Jembo wrote: ↑Sat Nov 03, 2018 4:05 pm Typically 19” wheels are heavier than 18” by a noticeable margin (unlike 17/18” weight difference) - that was my experience with AUDI wheels.... which translates into less fuel efficient.
The wheels alone will be heavier but surely the tyres will be lighter as there is less rubber due to smaller sidewall if you go for standard sizes.
Or am I talking crap?
- Valor1
Thanks. Tires are Michelin Pilot Sport 4S 255/19" front and 285/20" rear.
- IMG_0079.JPG (318.23 KiB) Viewed 1839 times
- IMG_0083.JPG (281.22 KiB) Viewed 1839 times
- IMG_0032.JPG (205.64 KiB) Viewed 1839 times
- Ewazix
At last, someone who understands that tyre/suspension systems NEED controlled compliance to maintain grip, beyond a certain point bigger wheels, lower profiles and lower/stiffer suspension will do squat for performance on real UK roadsLazza wrote: ↑Sat Nov 03, 2018 12:04 am Reducing tyre flex improves steering response but loses grip. Grip comes from maximising contact patch and keeping it in contact with the tarmac and tyres with more give in them do that better. That’s the main reason non run flats are so much better than run flats.
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
