New tyres
- Moomoo1979
New tyres
I’m sure it’s been mentioned before but I have just changed my run flats for non run flats. Pirelli p-zero was my choice and I have to say what a difference I would highly recommend doing this and as a result I have a set of 4 run flats for sale. I should have done this sooner.
Look after your car and it will look after you
New tyres
Good choice, I changed over from runflats a few weeks ago and the difference is remarkable. I use mine for commuting and its so much easier to live with, like you I should have done it years ago
2011 X3 30d MSport black, 8-speed auto, leather everything
2011 Bimmer Z4 35i diamond black, 6-speed manual, full caboodle (hibernating)
- Silverzedtom
New tyres
cant speak for the others but I’m running 19’s and non rft.
It’s almost more important to change when using 19’s. As the wheel size goes up the rubber thickness goes down usually as well to keep a similar rolling diameter. That means less absorbtion of shock and ultimately cracks alloys.
Ditch the runflats and get some premium rubber on
I use Vredstein ultrac vortis and will keep going back for more until they stop making them. Just make sure you keep two or three cans of tyre weld in the boot.
E85 2.5si
F55 Cooper S
F55 Cooper S
- Zed Baron
New tyres
Ive just changed my Pirelli's (happy with them) to Goodyear Eagle F1s (better rating in the wet) on my 19s, on the rears this time I went for 255/35/19 instead of 255/30/19. Does feel more comfortable and hopefully will protect the rims a bit more but looking at the state of the roads that will be hard.
- Moomoo1979
New tyres
I have the 19inch wheels and wouldn’t go back to run flats
- Moomoo1979
New tyres
I was going to get the slightly greater profile on the backs but was advised by quite a few not to do it. It’s done with the lower profile for a reason as doing this will raise the back and geometry of the rear will be sacrificed by uneven tyre wear.Zed Baron wrote: ↑Sun Aug 26, 2018 3:18 pm Ive just changed my Pirelli's (happy with them) to Goodyear Eagle F1s (better rating in the wet) on my 19s, on the rears this time I went for 255/35/19 instead of 255/30/19. Does feel more comfortable and hopefully will protect the rims a bit more but looking at the state of the roads that will be hard.
- Zed Baron
New tyres
While the car was in at BMW I spoke to service dept and they said it would be fine, the car feels more comfortable to drive and every depression in the road surface is not as noticeableMoomoo1979 wrote: ↑Sun Aug 26, 2018 8:05 pmI was going to get the slightly greater profile on the backs but was advised by quite a few not to do it. It’s done with the lower profile for a reason as doing this will raise the back and geometry of the rear will be sacrificed by uneven tyre wear.Zed Baron wrote: ↑Sun Aug 26, 2018 3:18 pm Ive just changed my Pirelli's (happy with them) to Goodyear Eagle F1s (better rating in the wet) on my 19s, on the rears this time I went for 255/35/19 instead of 255/30/19. Does feel more comfortable and hopefully will protect the rims a bit more but looking at the state of the roads that will be hard.
- road warrior
New tyres
I need to change as I am sick of the go cart twitch and I'm really hoping dumping the runflats will cure it, best describe it as the electric twitch on the front wheels you get on a remote control car when you turn it on and the sender/receiver is buggered. When it does that at 60mph it scares the s**t out of you.
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
