Battery when garaged over winter
obelix54
Post by obelix54 » Sat May 12, 2018 8:23 am
Hi,
I plan to leave my car in the garage for the winter months and wondered if the battery will be ok over that time or if I need a trickle charger ?
Any info' gratefully received.
2009 BMW Z4 3.0
2014 BMW X3 (F25)
2023 Mini Electric
Smartbear
Post by Smartbear » Sat May 12, 2018 8:55 am
obelix54 wrote: Sat May 12, 2018 8:23 am Hi,
I would leave it connected to an intelligent charger, you can leave it switched on permanently without worrying about it :thumbsup:
e85 3.0si sold
HillWalker
Post by HillWalker » Sat May 12, 2018 9:20 am
A trickle charger and a intelligent charger are different, a trickle charger will just keep going putting in a very low amperage so you could leave it on for 24 hrs or more, a intelligent charger will charge the battery till it's fully charged then stop and if you leave it connected will keep topping up the battery.
The best intelligent chargers are ctek or optimate most people on here go for the ctek which is what I've got and am very pleased with.
step_change
Post by step_change » Sat May 12, 2018 10:14 am
Not the cheapest but this is the one you want.
https://www.amazon.co.uk/CTEK-MXS-5-0-R ... ek+mxs+5+0
Gone :( : 2013 35is, Melbourne Red, DCT, Nav, Comfort pack
Gone: 2007 2.5is, Montego Blue, Auto, Nav
Scooba_Steve
Post by Scooba_Steve » Sat May 12, 2018 10:35 am
Get a CTEK :thumbsup:
Busterboo
Post by Busterboo » Sat May 12, 2018 10:56 am
CTEK or, better still, drive the car. :thumbsup:
Vidi, vici, veni
TitanTim
Post by TitanTim » Sun May 13, 2018 8:10 am
I've used cteks for years and they are good, essential if you plan storing the car for months. The only issue I've had is the mode selector button tends to go dodgy after a few years making it difficult to cycle through the modes but apart from that fit and forget. Only got around to getting the 140i out last week after being stored since September and fired up first time otherwise the battery would have been dead.
Tim.
enzed4
Post by enzed4 » Sun May 13, 2018 8:48 am
TitanTim wrote: Sun May 13, 2018 8:10 am The only issue I've had is the mode selector button tends to go dodgy after a few years making it difficult to cycle through the modes but apart from that fit and forget.
Tim.
I thought this was just mine :-) It's done it since new so I just learned to press the outer edge of the button to stop it jumping across multiple modes.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
TitanTim
Post by TitanTim » Sun May 13, 2018 9:06 am
enzed4 wrote: Sun May 13, 2018 8:48 am
Tim.
Think I'm on my third unit in 13 years due to the mode button. They seem fine when new but over time it gets more difficult cycling through modes and either it won't select or as you say jumps through them. Its odd because I only actually press the button no more than twice a year as once the car is stored and hooked up it's left. I don't think it's so much wear but poor design as it can happen when the unit is new.
One of reasons I like them is because they have a mode for agm stop start batteries, I'm guessing these need charging differently or require a higher charge rate, not sure.
Tim.
eff1guy
Post by eff1guy » Sun May 13, 2018 10:09 am
Tim.
Mine's gone like this too, PITA sometimes as it takes several attempts to get the correct mode :headbang: But other than that it works fine
Next Z landed ..... Z3 3.0i Sport Roadster
Z4 35iS ..... Gone to a new home
jabber
Post by jabber » Sun May 13, 2018 11:24 am
TitanTim wrote: Sun May 13, 2018 8:10 am I've used cteks for years and they are good, essential if you plan storing the car for months. The only issue I've had is the mode selector button tends to go dodgy after a few years making it difficult to cycle through the modes but apart from that fit and forget. Only got around to getting the 140i out last week after being stored since September and fired up first time otherwise the battery would have been dead.
Tim.
Mines is the same but I have found that if I connect it up but don’t touch any buttons then leave it for 5 minutes the mode button functions correctly
Z less again
mentalnerve
Post by mentalnerve » Sun May 13, 2018 12:37 pm
I've got 2 chargers the ctek mxs7 £80 with the cigarette lighter plug when I bought it. which has various functions and is brilliant for bringing a battery up from the dead and reconditioning it. The other one is a £13 one from Aldi which is useless when the voltage drops below 9v but great as trickle charger
obelix54
Post by obelix54 » Sun May 20, 2018 10:10 pm
Thank you all for your advice, CTEK it is !
2009 BMW Z4 3.0
2014 BMW X3 (F25)
2023 Mini Electric
bob4333
Post by bob4333 » Mon May 21, 2018 8:21 am
I doubt you'll regret buying a CTEK, had mine for 10+ years and no malarky.
They're extremely capable and even go into a maintenance routine if left on permanently with the car unused. Even BMW dealerships use them for showroom cars.
Sure I read somewhere they also have a programme for bringing a battery back from the dead. Now that's a feat!
Busterboo
Post by Busterboo » Mon May 21, 2018 10:58 pm
mentalnerve wrote: Sun May 13, 2018 12:37 pm I've got ... the ctek mxs7 £80 with the cigarette lighter plug ...
Can you use it on an E89 through the cigarette lighter?
Vidi, vici, veni
