Exhaust Flap Mod - Cap size?
Hi all,
I want to give the 'Golf Tee' mod a try, but would prefer a more secure device than a golf tee . Does anyone know the required Inner Diameter for each end (if they're different) so I can get some proper vacuum line bungs/caps instead? I've heard somewhere 3/16" but can't be sure and dunno if he meant ID/OD let alone which metric equivalent would be best.
Thanks,
Chris
Thanks,
Chris
Pure Traction 35iS - Sold!
Carbon Black E86 3.0si Coupe - Gone but not forgotten
Quick update for the benefit of others, the answer is 4mm !!
These are perfect, with a 4mm inner diameter.
http://www.autosiliconehoses.com/silico ... -32mm.html
Saves faffing with golf tees or any other mild bodges :p.
- bob4333
Quite a lot of chat about this mod some months back ranging from makes "some difference" to "not much". What have you found.....?
You can also just disconnect the solenoid in the boot.
- ronk
Is a switch an option in this case ?
I guess with some fiddling and the right connectors but frankly it doesn’t make a vast difference so not likely worth it.
I plan to explore removal of baffling from the non quiet phase of that particular silencer so the the change is more notable and to increase the side to side warble from the dual exhaust.
- ronk
Thanks for the advice
With that in mind I think I will leave the system well alone - it would be good to be able to swap with the flick of a switch but it’s not something that’s going to keep me awake at night!
It doesn't make a huge difference. Noticeable on start up and general pootling around town, not so much when hooning. It's maybe 5% louder, not a problem when cruising at all imo.
- Huzee4
Thanks all, silicon end caps orderedChris1712 wrote: ↑Fri May 18, 2018 9:27 pm Quick update for the benefit of others, the answer is 4mm !!
Steve
E85 2.5 SE Maldives blue
E89 20i Estoril blue
disconnecting the solenoid exposes the terminals to the elements, the hose is the best option.
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- ronk
No intention of leaving Terminals exposed but bridging the feed to the solenoid with an in car switch.
Pointless effort Ronk, it doesn’t make enough difference to bother. Once done I’m sure you’d be happy to leave as is.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- ronk
I agree - I think it’s loud enough as standard - only the change down in sport is something special
I meant do the mod then leave as is, it’s worth doing as it’s a 30 sec job with the caps and does make it sound a little more burbly and deeper but not nearly enough to need to have it switched.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- ronk
I understand
However I do think is nice to have a stealth mode - I use the term “stealth “ very loosely!
