On style 326 ?warmasice wrote: ↑Sun Jul 01, 2018 1:37 amMr Wilks, what size do you suggest for the fronts?mr wilks wrote: ↑Wed Apr 18, 2018 8:13 pmAssuming 9.5j & not a ridiculous offset then no problem at all , lots of clearance with increased wheel protection & ride comfort .Arcade.Eyes wrote: ↑Wed Apr 18, 2018 8:02 pm Any know if : 255/35R19 will fit on the rear without rubbing? All tyre purchase companies suggest 255/ 30 r 19 but if I can get some extra side wall I would for comfort.
I always go 255 35 on 19s , no reason not to
Tyres
- mr wilks
Tyres
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Tyres
Yes. Thinking of going up on the front like the back for a more comfort and match the rolling circumference a little more. However, some have had rubbing issues at the front and so I'm confused as to what tyre size to order.
- mr wilks
Tyres
Not sure id go over 235 35 on front 8j 326
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Tyres
How about 225/40? Or do you recommend keeping the front the same and just going up on the profile at the rear?mr wilks wrote: ↑Sun Jul 01, 2018 11:10 amNot sure id go over 235 35 on front 8j 326
- mr wilks
Tyres
I fitted 225 40 19 to a set of 8.5j wheels on a 23i but only to reduce arch gap without lowering springs , on Msport with 326 8j id say 235 35 was the max you would want on front without looking over tyred
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Tyres
Thanks buddy. Always appreciate your input.
Has anyone else here fitted 235 35 on 19" 326 wheels without any rubbing? If so, is your car lowered and what brand of tyres are you running?
Tyres
I fitted 255/35 rear and 235/35 fronts on my 35is a couple of months ago, no problems and 100% nicer car to drive, obviously non runflats Goodyear Asymmetric 3s
- Zed Baron
Tyres
I
Ive just changed my rears over to 255/35/19 (from 255/30/19) and the car seems fine, don't seem to feel every bump in the road. I did check with my local BMW dealer when the car was in for the recall and they said it was fine. Went for Goodyear eagle F1's as they had a better rating for performance in the wet compared to the Pirellis I have on at present £580 to change all four tyres 255/35/19 r + 225/35/19 fArcade.Eyes wrote: ↑Wed Apr 18, 2018 8:02 pm Any know if : 255/35R19 will fit on the rear without rubbing? All tyre purchase companies suggest 255/ 30 r 19 but if I can get some extra side wall I would for comfort.
Tyres
I've heard good things about that tyre. Goodyears are known for a slightly softer sidewall too, so should help the ride comfort. Are you on standard springs, msport or is is lowered?HillWalker wrote: ↑Mon Jul 02, 2018 8:46 am I fitted 255/35 rear and 235/35 fronts on my 35is a couple of months ago, no problems and 100% nicer car to drive, obviously non runflats Goodyear Asymmetric 3s
Tyres
As above, wondering what springs you're on at the moment? ThanksZed Baron wrote: ↑Mon Jul 02, 2018 1:51 pm IIve just changed my rears over to 255/35/19 (from 255/30/19) and the car seems fine, don't seem to feel every bump in the road. I did check with my local BMW dealer when the car was in for the recall and they said it was fine. Went for Goodyear eagle F1's as they had a better rating for performance in the wet compared to the Pirellis I have on at present £580 to change all four tyres 255/35/19 r + 225/35/19 fArcade.Eyes wrote: ↑Wed Apr 18, 2018 8:02 pm Any know if : 255/35R19 will fit on the rear without rubbing? All tyre purchase companies suggest 255/ 30 r 19 but if I can get some extra side wall I would for comfort.
- Zed Baron
Tyres
the car is a 23i sdrive SE, it has 19" 326's and the original suspension without any modificationswarmasice wrote: ↑Tue Jul 03, 2018 10:46 pmAs above, wondering what springs you're on at the moment? ThanksZed Baron wrote: ↑Mon Jul 02, 2018 1:51 pm IIve just changed my rears over to 255/35/19 (from 255/30/19) and the car seems fine, don't seem to feel every bump in the road. I did check with my local BMW dealer when the car was in for the recall and they said it was fine. Went for Goodyear eagle F1's as they had a better rating for performance in the wet compared to the Pirellis I have on at present £580 to change all four tyres 255/35/19 r + 225/35/19 fArcade.Eyes wrote: ↑Wed Apr 18, 2018 8:02 pm Any know if : 255/35R19 will fit on the rear without rubbing? All tyre purchase companies suggest 255/ 30 r 19 but if I can get some extra side wall I would for comfort.
- bmw.jpg (295.95 KiB) Viewed 724 times
Tyres
The cars is a 35is so m sport suspension and adaptive dampers otherwise just standard.warmasice wrote: ↑Tue Jul 03, 2018 10:45 pmI've heard good things about that tyre. Goodyears are known for a slightly softer sidewall too, so should help the ride comfort. Are you on standard springs, msport or is is lowered?HillWalker wrote: ↑Mon Jul 02, 2018 8:46 am I fitted 255/35 rear and 235/35 fronts on my 35is a couple of months ago, no problems and 100% nicer car to drive, obviously non runflats Goodyear Asymmetric 3s
