Where is the connector for doing that? I think mine is disconnected.
Carly DIY on 2010 Z4 E89
- Diego_F
2012 E89 sDrive35is Black Sapphire
- R.E92
It's just behind the drivers side exhaust outlet. If you get on your back and look up at the exhaust you should be able to see the small rubber tube.
I would like to point out that you can code out the fade on the halo's for the E89 as I have done it.
I fitted xenon's to my angel eyes(Halos) and they would flicker on and off, it took me a while to find that fade on and fade off feature with Carly but I did find it and switched it off and now the halos switch on with zero flicker.
I have actually coded quite a fair amount of stuff with Carly. folding mirrors. roof in motion. DVD at high speed. brightened the halos before i replaced with xenon's. digital speed display. turned on actual speed instead of corrected speed in the digital display.
made the key click out and release by holding engine start for longer than a second so I no longer have to press the key in to unlock it and remove it after switching off the engine.
I can't remember all the things that I coded but it was allot! VERY useful app!
