First Service E89 2.0 2016
When I change my oil, I go for a good 10 mile drive to get the engine nice and hot and drain the oil as soon as I get back. I let it drain for about 30 mins while I tart around with the filter and generally tart about. I then allow the jack down at different angles to get even more oil out. There is no way that will happen in a garage/dealers.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
OnlineR60BBA
Most reputable garages know how to drain oil properly pal.firebobby wrote: ↑Wed Apr 04, 2018 6:16 pm When I change my oil, I go for a good 10 mile drive to get the engine nice and hot and drain the oil as soon as I get back. I let it drain for about 30 mins while I tart around with the filter and generally tart about. I then allow the jack down at different angles to get even more oil out. There is no way that will happen in a garage/dealers.
https://youtu.be/cV62IpiN-cw
Current: 2002 E46 M3
Current: 2004 R53 Cooper S
Current: 2005 997 Carrera S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
That's just for the camera mushR60BBA wrote: ↑Wed Apr 04, 2018 6:53 pmMost reputable garages know how to drain oil properly pal.firebobby wrote: ↑Wed Apr 04, 2018 6:16 pm When I change my oil, I go for a good 10 mile drive to get the engine nice and hot and drain the oil as soon as I get back. I let it drain for about 30 mins while I tart around with the filter and generally tart about. I then allow the jack down at different angles to get even more oil out. There is no way that will happen in a garage/dealers.
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
I got a 3yr service pack for my 2014 35is for £799 when it had its first MOT. Covers the next 3 MOT's, the next three services and the next three brake fluid changes. Just bought my 19yr old a 2018 218i SE Sport and a service pack for that was £399 which covers the same apart from two of the MOT's. Makes my 35is service pack look cheap?
- Huzee4
10,000
Out of curiosity, what is the mileage of the car?
[/quote]
[/quote]
Steve
E85 2.5 SE Maldives blue
E89 20i Estoril blue
- Huzee4
Not a clue !
Steve
- Nictrix
I think they charge labour in units, if I remember correctly, each unit is 5 minutes, so the first one is 10 minutes for the standard scope (is that where they plug it into the computer to check for error codes etc?).
So the second £21.67 is 10 minutes to change the microfilter, and £37.26 for the actual filter.
At that rate, it equals £130 an hour labour.
However, the oil filter service bit doesn't add up. It looks like they've charged 15 minutes labour, but is that feasible? Then they've charged 5 units for oil....but the 12.5 for waste disposal is actually £12.50.
Add it up according to the breakdown on the left shows parts cost £50.81....which suggests oil .....
oh fcuk it, I'm lost
2011 E89 sDrive20i
Yep, not easy to decipher is it. Doesn't make much sense.ihadablackdog wrote: ↑Mon Apr 23, 2018 8:23 pm I think they charge labour in units, if I remember correctly, each unit is 5 minutes, so the first one is 10 minutes for the standard scope (is that where they plug it into the computer to check for error codes etc?).
Doesn’t need deciphering, it’s a big fat stinking rip off and that’s that....warmasice wrote: ↑Mon Apr 30, 2018 7:57 pmYep, not easy to decipher is it. Doesn't make much sense.ihadablackdog wrote: ↑Mon Apr 23, 2018 8:23 pm I think they charge labour in units, if I remember correctly, each unit is 5 minutes, so the first one is 10 minutes for the standard scope (is that where they plug it into the computer to check for error codes etc?).
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Smartbear
That’s what I like about you John, you say it like it isjohn-e89 wrote: ↑Mon Apr 30, 2018 8:08 pmDoesn’t need deciphering, it’s a big fat stinking rip off and that’s that....warmasice wrote: ↑Mon Apr 30, 2018 7:57 pmYep, not easy to decipher is it. Doesn't make much sense.ihadablackdog wrote: ↑Mon Apr 23, 2018 8:23 pm I think they charge labour in units, if I remember correctly, each unit is 5 minutes, so the first one is 10 minutes for the standard scope (is that where they plug it into the computer to check for error codes etc?).
e85 3.0si sold
That being said, whats the point of an itemised bill if you still can't see where the money's gone.
....I guess its in their interest to make it this confusing, to hide where the money is going.
Take it back and ask for an explanation in english!
2011 E89 sDrive20i
- Smartbear
The service pack on my car covered part & labour, it also had an add on called mot protect (or similar) which didn’t cover the cost of the test itself but covered against major components being faulty, it excludes normal wear & tear items like brakes and tyresjasonofbillinge wrote: ↑Tue May 01, 2018 8:37 pmmine has come with that till 2021 or 50,000 miles - does it include parts and labour does it include MOT's too ?
e85 3.0si sold
