Air con and fuel consumption
mcbutler
Post by mcbutler » Tue Mar 13, 2018 4:53 pm
Hi All,
My car is a 23i and I do regular trips of over 300 miles to visit poorly parent.
Obviously its boring on the motorway so I decided to do some 'experiments' with the instantaneous fuel consumption indicator and air con. The reason being I had been told use of air con increases fuel consumption!
Well, they are damn right, after picking a flat stretch of motorway I set the car on cruise at 70mph and noted the instantaneous readout. I then engaged the air conditioning to see what the difference was.
Can you believe 10 mpg less with air con engaged!!!, thats a 25% reduction in economy......
Worth bearing in mind, open the windows I reckin in future...
Online
Crazy Harry
Post by Crazy Harry » Tue Mar 13, 2018 5:31 pm
Don't you mean increases fuel consumption /reduces mpg?
Why not try the experiment again with the air con off and windows down - I bet that will shock you. Most wagons now have air con to save fuel - the disruption to air flow from an open window causes too much drag and fuel burn. What's that old saying 'you don't get ouwt for nouwt'
ph001
Post by ph001 » Tue Mar 13, 2018 5:32 pm
Something not right there (was there a big headwind on one run and not the other for example). Car a/c takes around 4kW (5hp) max so that's about 2.5% of your total engine output. No way it should affect economy by 25%,
2004 E46 M3 coupe manual.
Busterboo
Post by Busterboo » Tue Mar 13, 2018 6:09 pm
Looked at another way, when it's hot, do you sit there and sweat, thinking, 'Mmm, this is good. Really saving fuel'?
Vidi, vici, veni
mcbutler
Post by mcbutler » Tue Mar 13, 2018 6:36 pm
I did it twice, on a long flat run on the M62 and also on the M5.
Both times i did no air con followed by air con on, then air con off again. Both runs hundreds of miles apart showed pretty much the same reading..
mcbutler
Post by mcbutler » Tue Mar 13, 2018 6:41 pm
You are probably right (theoretically) but give it a go and see what you get..
Does the power drawn change with engine RPM? probably yes as the compressor speed/belt drag/internal resistance is directly linked to engine speed.
mr wilks
Post by mr wilks » Tue Mar 13, 2018 7:15 pm
Idle curiousity prompts me to ask what the MPG figures were :?
Z history
E86
E85
Grey///MR
3.0Si E85
E89 23i
3.0Si E85
E86
3.0Si E85
Imola///MR
35i Msport 6spd
E86
E86
Silver///MR GruppeM :driving:
https://www.instagram.com/andybmwheels/
