35is: Replace exhaust tips. How?
Hello.
I have seen some pics of the exhaust off the car but I still haven't found an answer.
Are the OEM tips spotwelded? I like the stock sound actually but want to replace the tips.
Does anyone know the outer diameter of the pipe connteced to the tip?
Thinking about 90mm tips.
My cars: http://WWW.GARAGET.ORG/PHILLY
- markplant
Mr Wilks had his done on his 35i , iirc
Correct.
And Another question is if you need to remove the exhaust to replace just the tips?
- mr wilks
Mine were cut off without removing bumper or boxes , then new ones welded on , took around 30mins for both sides , unsure of the sizes though the new ones i believe are 90mmPhilly_Sweden wrote: ↑Fri Mar 02, 2018 11:18 amCorrect.
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- Bombardino
Ditomr wilks wrote: ↑Fri Mar 02, 2018 11:37 amMine were cut off without removing bumper or boxes , then new ones welded on , took around 30mins for both sides , unsure of the sizes though the new ones i believe are 90mmPhilly_Sweden wrote: ↑Fri Mar 02, 2018 11:18 amCorrect.
Yes but did he cut of the whole pipe or just the spotwelded tip ON the pipe?Bombardino wrote: ↑Fri Mar 02, 2018 12:14 pmDitomr wilks wrote: ↑Fri Mar 02, 2018 11:37 amMine were cut off without removing bumper or boxes , then new ones welded on , took around 30mins for both sides , unsure of the sizes though the new ones i believe are 90mmPhilly_Sweden wrote: ↑Fri Mar 02, 2018 11:18 am
Correct.
- step_change
I thought the two segments joined at the rear from a common manifold at the engine end? So do 1,3,5 and 2,4,6 feed different sides of the exhaust?
Why is the box on the right smaller than the one on the left?
Gone : 2013 35is, Melbourne Red, DCT, Nav, Comfort pack
Gone: 2007 2.5is, Montego Blue, Auto, Nav
- SteveSmith
They join in the middle so it makes no difference.step_change wrote: ↑Fri Mar 02, 2018 4:06 pm I thought the two segments joined at the rear from a common manifold at the engine end? So do 1,3,5 and 2,4,6 feed different sides of the exhaust?
28i M Sport - Alpine White / Canberra Beige, 19" M359’s, H&R’s / Eibachs, BMS Stage 1 - 271bhp, Front Splitter, CF Rear Lip, Alcantara Steering Wheel and Brembo 4 pots
- Bombardino
Philly_Sweden wrote: ↑Fri Mar 02, 2018 2:05 pmYes but did he cut of the whole pipe or just the spotwelded tip ON the pipe?
Aren't the tips an interference fit and don't they just turn off?
Vidi, vici, veni
- srhutch
- Moderator
Wouldn’t have thought they would cut where your top line is due to valve. Just grind back the spot welds.
- Bombardino
I had the pipe cut back just short of the bypass pipe, the new tail pipes are then welded in place, all done without removing the bumper.
Do you have any pics to share?Bombardino wrote: ↑Sat Mar 03, 2018 2:06 pm I had the pipe cut back just short of the bypass pipe, the new tail pipes are then welded in place, all done without removing the bumper.
- Bombardino
Not the best photos but as good as you get until the snow disappears.
- C2986B34-05C3-49B9-A601-D4DB36E5B482.jpeg (404.2 KiB) Viewed 1052 times
- A1708F34-13BD-46DA-863F-0CFF2ACDE07E.jpeg (323.05 KiB) Viewed 1052 times
