Advice on brake discs please
Markg.uk1
Post by Markg.uk1 » Wed Jan 03, 2018 5:17 pm
I have a warped front disc so i'm gonna replace all four and i would like to replace with drilled grooved discs front and back
but can't find any it's for a e89 35i msport 2010 ,just want discs and pads not calipers
Thanks guys
Zoomer
Post by Zoomer » Wed Jan 03, 2018 6:13 pm
M tec do them for 6cylinder e89 models
Sterling Grey 3.0i E85 Black Heated Leather M sports seats , 224's ,Sat Nav, Bluetooth, Xenons, PDC, Gaptech ,Cruise and a nice warm garage. NOW GONE
Silver 3.0i Z4 NOW GONE
Umfaan
Post by Umfaan » Thu Jan 04, 2018 10:21 pm
Correct.....just ordered full set front and back from MTEC .......very helpful bunch ........call them.....02871861816 , they will send you a link to there website and you order there, and get 10 % discount ........they will coat them as well Silver , Black or Gold for £25 for 4 discs.
Ducklakeview
Post by Ducklakeview » Thu Jan 04, 2018 10:37 pm
I wouldn't go for drilled, they can, and do suffer from cracking - Get yourself the grooved and dimpled M-Tec one's..
Mike
Player 1
Post by Player 1 » Thu Jan 04, 2018 11:01 pm
In all honesty I'd stick with BMW items. They're of good quality and the fronts have aluminium centres so will have a significant weight saving over mtec which to me is worth far more than the "look" gained from grooves, holes, dimples or whatever else they can attack the disc with :poke:
Baza
Post by Baza » Thu Jan 04, 2018 11:23 pm
Are you wishing to replace them for the look or for better brakes. I spent a lot of time earlier this year researching drilled and grooved V standard smooth faced discs. From the info gained it appears that after market supplied D&G discs are prone to cracking and do use pads up quicker They can also be noisy. In the end I went for ATE discs (a BMW supplier) with new pads but did change the brake hoses to braided S/S which do provide a more sharper and progressive braking. This is just my opinion if you ask 10 different people you will probably get 10 different answers . You pays your money and makes your choice.
Panther Kallista 2.8
S Drive 3.0i E89 2009 Space Grey Coral red Int 18" 295 wheels
Markg.uk1
Post by Markg.uk1 » Fri Jan 05, 2018 11:05 pm
Thanks for all the advice i was just going for looks really but hadn't thought about weight or noise
i'll have to have a ponder on that one :headbang:
cheers guys :thumbsup:
Markg.uk1
Post by Markg.uk1 » Fri Jan 05, 2018 11:08 pm
Just been on mtec and there is no discs listed for the 35i ?
Lazza
Post by Lazza » Fri Jan 05, 2018 11:43 pm
I tried drilled & grooved EBC discs on my MX5 and hated them. Noisy, not just when braking. Even just driving past anything like a wall or fence I could hear them. Sometimes braking was smooth but often I could feel it through the pedal, almost like ABS. it did nothing at all for braking performance or fade resistance.
This was on a 240bhp supercharged MX5 used hard on track as well as on the road.
They looked good but other than that I couldn’t recommend them at all. After that I just used the cheapest plain discs I could find with uprated pads. Much much cheaper, quieter with perfect braking performance.
Z4 S-Drive 35i
Audi TT S-line
Mazda MX5 Mk2.5 (for sale)
Wokingham Berkshire
Baza
Post by Baza » Fri Jan 05, 2018 11:52 pm
Like I said I did a lot of research on D & G discs for E89 models whilst a lot of companies list them, when you enquire or check sizes they are not available for the E89, or only front discs are available. The only companies I found who could supply were Tarox (japanese sports brakes) I had a lot of contact with them ( the UK office) and whilst they listed them for E89 3.0i the sizes were incorrect which in the end they admitted but advised they could supply the correct dia for my car but at over twice the price as listed. The other company where Zimmerman who listed them and were the correct size but on reading various user reports I did not proceed. Bearing in mind mine is a 3.0i and your is a 35i there may be a difference in diameter so you may be luckier than me. But for my money stay with standard smooth plain discs .
Markg.uk1
Post by Markg.uk1 » Sat Jan 06, 2018 9:43 am
Ok thanks so much for the advice guys gonna stick with the standard discs
brilliant forum :D
Markg.uk1
Post by Markg.uk1 » Sat Jan 06, 2018 8:29 pm
Any advice on the best pads to get guys ?
mcbutler
Post by mcbutler » Sat Jan 06, 2018 8:42 pm
Slotted only fella, any brake expert will tell you that drilled are often inferior to OEM. You can google for advice, loads on youtube etc. Drilled only sell because they are aesthetically pleasing.
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Nictrix
Post by Nictrix » Sat Jan 06, 2018 11:05 pm
mcbutler wrote: Sat Jan 06, 2018 8:42 pmSlotted only fella, any brake expert will tell you that drilled are often inferior to OEM. You can google for advice, loads on youtube etc. Drilled only sell because they are aesthetically pleasing.
Im sure theres a lot more to it than looks.
The discs will cool quicker if they are drilled for a start.
If there were no benefits manufacturers would only have solid discs on vehicles from the factory as drilled discs must cost more to produce.
Not just talking about cars here but most bikes have drilled discs.
Gaffa22
Post by Gaffa22 » Sun Jan 07, 2018 2:12 pm
Bike discs are a bit different, they are not vented, and are made of expensive carbon steel.
For race cars expensive drilled discs do service a purpose, it's actually to let the gas escape.
But cheap drilled discs are a waste of time in my opinion
2010 E89 35i DCT
2017 Honda CBR1000RR fireblade
2016 Honda VFR1200F
