Just noticed this so not sure how long it's been like it
Presume these gaps should be smaller which points to the bumper not being attached correctly?
Panel gap question
Panel gap question
Z4 ‘13 20i Mineral Grey
Z4 '07 2.5Si Montego Blue
- jabber
Panel gap question
Definitely looks wrong to me probably needs refitting to sort it
Z less again
- Argyll Andy
Panel gap question
There’s also small black retaining brackets behind there, make sure they’re not snapped/detached
Part 14
https://www.realoem.com/bmw/enUS/showpa ... Id=51_7179
Part 14
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
- 1000rr
Panel gap question
Need new bumper clips.
Panel gap question
Hi,
Yep - looks like the clips are broken or the bumper became unhooked - I understand it can happen if the bumper gets caught reversing off a kerb or something similar.
Hit the lower part of the bumper just in front of the lips and if you hear something rattling around then the clips are broken and fallen down.
As long as the mount moulded into the bumper is intact then it should be straight forward - undo the screws on top and underneath then a jiggle to lift it off. Plenty of videos on Youtube
Cheers!
Andy
Cheers!
Andy
Panel gap question
This would be the easiest solution if nothing is broken.
But for me it didn't work. Gap remained too big. Decided to wait for warmer weather in the hope the bumper would be more flexible. Then I am going to try again by detaching the bumper from the retaining brackets -> moving up the brackets -> attach the bumper to the brackets
I dont think the gap has to be very small since the gap between the bonnet en front panel isn't very small eather
Panel gap question
if its the same both sides its probably ok, unless both clips have broken.... Give it a wiggle.....
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
