Cruise control retrofit
Hello everyone
I am having issues retrofitting cruise control to my 2011 bmw z4 35is.
I tried one set of stalks and kindly had the car coded by a forum member called Dave. This didn't work so we assumed the stalk to be faulty so ordered another set, 're installed and still no luck. As they had been swapped over the usual traction and tyre warning lights come on.
This is deeply frustrating as the car has been coded and Dave followed the identical steps that he done when installing on his ow z. If anyone can provide any help we'd greatly appreciate it.
I got stuck there too and it was due to the fsw_psw.trc being named wrong... here's the post I did in the original thread.
Restart NCS expert as before, load profile, f1, f3, choose chassis/module (cas), back. That should have written the full car trace file fsw_psw.trc to the ncsexpert/work folder. I renamed my fsw_psw.trc file to .man (because the man file was empty - that was the problem all along).
Following the instructions again - the job was already SG_CODEIREN, the guide says push "F4 process car" and wait. For a start its F3, not F4, I wasn't sure which was right but it is F3 "process car", then F1 "code car" - this isn't mentioned in the guide at all. Then you have to wait while the coding runs which takes a little while. Lights and gongs go off, and eventually I got an error in CABD, (as I have seen others get), but this seems to be ok (so far). Other's have said to code the DSC unit rather than the whole car, but I'm not sure how to select it individually. The whole NCS Expert is very user unfriendly (and I'm no expert!). I have no idea what really is going on, it was just trial and (mainly) error.
The guide then says to run DIS to reset the steering angle sensor , this took me ages because DIS runs on a VM and I couldn't set the VMware network properties so I had to reinstall XP. Plus DIS takes a long time to actually get to the bit to reset it (and its very vague in the guide on what to do). Dont do that - as other people have said, just use Tools32, load the module (DSC_89 in my case), and then double click the 'lenkwinkel_dsc_abgleichen' (quite a way down in the first list box). the lights WILL GO OFF AND STAY OFF!.
- Phoenixboy
off topic, sorry, but am sure I saw your car going past my work in marsh barton Exeter recently.clarker63 wrote: ↑Fri Jan 18, 2019 4:01 pm I got stuck there too and it was due to the fsw_psw.trc being named wrong... here's the post I did in the original thread.
E89 s drive 30i manual/gone
space grey
Carbon interior trim
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
Gone, E85 Ruby Black.
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
Could be! I'm not normally that side of town as I work near the airport and come down the M5 from Willand near Tiverton.. I've not spotted you yet though. There's not too many Z4 E89's around these parts!
- Phoenixboy
no, we are rare in the south west.
I normally head south from Exeter on my drives, although have been up to west bay a few times.
will keep my eyes peeled
saying that there are some decent runs up to north devon which I used to do on the motorbikes, like bude, minehead etc, but have yet to do them in the z.
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
There is a thread in the e89 How-To section by myself where I have posted an up to date How-To for the Cruise Control. This has been brought together with all the available information from a number of sources because not one guide is complete.clarker63 wrote: ↑Fri Jan 18, 2019 4:01 pm I got stuck there too and it was due to the fsw_psw.trc being named wrong... here's the post I did in the original thread.
When I did my car it was done following loads of research into the subject and following running some other retrofits so all of the info was brought together in one place. Temporarily the How-To has been taken down as I've discovered that two pieces of info were missing, so I'll place it back up once I've done this along with some new screen shots.
Meanwhile this was the guide (along with the missing detail) that was used on Ben's Z and I followed it and did everything exactly the same as I'd done to my own Z, but nothing is being displayed in the screen and it's not working. The trc (man) file has taken correctly (as I've checked it) and the VO is showing $544 as it should. So everything has gone through correctly, it just doesn't work
Ben is very nicely coming to see me again tomorrow so I can have another stab at it and try a couple of ideas out.
Dave
2011, 23i, Grey with Red leather.
You guys should work for NASA or GCHQ! Respect!AnubisZed wrote: ↑Fri Jan 18, 2019 6:23 pmThere is a thread in the e89 How-To section by myself where I have posted an up to date How-To for the Cruise Control. This has been brought together with all the available information from a number of sources because not one guide is complete.clarker63 wrote: ↑Fri Jan 18, 2019 4:01 pm I got stuck there too and it was due to the fsw_psw.trc being named wrong... here's the post I did in the original thread.
..........These men are using " PFM "...........................Pure f***ing Magic...
Rare in the South West, are you sure, not in Plymouth, including mine there were 3 in my gym car park this morning, another white one parked outside the tanning salon on the way home and then I passed one in the multi storey this evening!Phoenixboy wrote: ↑Fri Jan 18, 2019 4:29 pmno, we are rare in the south west.
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
Dave
OK all sortedAnubisZed wrote: ↑Fri Jan 18, 2019 6:23 pm
Firstly sorry Ben for messing you around
As for the coding, well even I can make a mistake!! I had a nagging feeling that I hadn't checked the VO code correctly and it turns out I hadn't! Checked it and $540 was in instead of $544. Now this is a very easy mistake to make (no excuses here though) so for anyone doing this, check and check again.
All rectified and now working perfectly
Dave
Easily done! It's a relief when everything finally starts working!
- tintoverano
following AnubisZed's excellent guide (thanks!!) checked the cable and software today
tomorrow doing it
wish me luck
tomorrow doing it
wish me luck
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
Best of luck bud.tintoverano wrote: ↑Fri Mar 22, 2019 9:21 pm following AnubisZed's excellent guide (thanks!!) checked the cable and software today
tomorrow doing it
wish me luck
Although I'm at work tomorrow I'm in the control room so will be available on here if you've got any questions
Dave
- tintoverano
I hope I won't need to disturb you, thank you
mSport 23i
