Tyre wear - just for information
Tyres bought 11 January 2017
Pirelli P Zero MO 92/94Y XL
On 35is
18,043 miles today
Front 225 40 R18 - approx. 5mm even across both
Rear 255 35 R18 - approx. 2mm inner, almost on central wear blocks, 1mm outer both
On 35is
18,043 miles today
Vidi, vici, veni
- Smartbear
Hmm, doesn’t increased tyre wear in the central section indicate over-inflation?
e85 3.0si sold
- vester86
Yes indeed. Although it's not much in this case
- mr wilks
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- srhutch
- Moderator
And your point is OP?
- pvr
Rear tyres wear out faster on a rear wheel drive car?
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
As the title said, "... just for information." Some people and I find tyre wear interesting.
Vidi, vici, veni
Yes, Rob, joking apart, I thought the same thing, of course, but when I asked my local tyre man - in the trade for 45 years - he said, 'A lot of BMs are like that.'
Mind you, as vester86 has said, "... it's not much in this case." And I was quite pleased with 2mm - 0.5mm - 1.0mm, inner to outer, bearing in mind they're rears.
That said, I wouldn't rule out reducing rear pressures if that would make wear even more even.
Vidi, vici, veni
- srhutch
- Moderator
- Nictrix
I think the information that was missed out in the original post was possibly the tyre pressures that were being used.
I assume that they were run on BMWs recommended pressures and Buster was trying to show that running these pressures resulted in this almost even wear.
I too have just removed the rear tyres from our car after running them consistently on recommended pressures that some say are too high (3.0 bar on the rear).
My results were a lot more even than Busters with even tread right across the whole tyre leading me to think that Busters alignment could do with a tweak to get even wear.
Different model and tyre manufacturer though.
- Nictrix
Possibly an alignment done to check everything is as it should be.
- jabber
Z less again
- srhutch
- Moderator
- Bing
That’s f***ed up man - looks like the little tike has had its legs chopped off !
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
Previous... 3.0Si Sport Roadster, Black Sapphire, Dream Red leather with lots of toys and lots of mods...
