Which Members have Carly and Where?
Can add Romford again with Carly available!
- road warrior
I think a new members map is being made, would it be possible to add the Carly locations as well?
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
HiChris1981 wrote: ↑Thu Jun 15, 2017 9:55 am Rugby, Warwickshire... don't mind coding for free if people want to come to me!
RyanB88, I'm assuming you have the N52 engine in your Z4 based on your signature.... do the parameters display anything on your Carly? I can't get anything on my 3.0si Coupe, tech support are apparently resolving it but wondered if any other N52 owners can use that function on theirs? I'm using iOs version of Carly.
I’m based in Northampton, so not too much of a trek to travel
What does the coding offer?
Forgive my ignorance, I’m a newbie Z4 owner
BMW E36 Compact “Dakar Yellow” (sold to make way for Z4 Coupe)
BMW E36 M3 Evo Vert (sold due to hit & run)
BMW E36 M3 Evo Vert (stolen written off)
BMW E36 M3 Evo Saloon (sold to buy Vert)
BMW E36 318is Coupe (sold to buy M3)
- road warrior
Now I'm confused.. I thought that was how it worked....
No I pre facelift need a cable, well mines does anyway.road warrior wrote: ↑Sat Nov 03, 2018 9:45 amNow I'm confused.. I thought that was how it worked....
I bought if off eBay for about £12
- kis
I'm sure a simple tick box could be added for Carly Coding? I'll message the guy.road warrior wrote: ↑Fri Nov 02, 2018 11:39 pm I think a new members map is being made, would it be possible to add the Carly locations as well?
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- kis
There is a difference between Apple and Android connections. Apple using iOS will work with a wifi adapter (in all cases).Buckley06 wrote: ↑Sat Nov 03, 2018 5:27 pmNo I pre facelift need a cable, well mines does anyway.road warrior wrote: ↑Sat Nov 03, 2018 9:45 amNow I'm confused.. I thought that was how it worked....
The Android phones will work via Bluetooth adapter, but I think for pre facelift (as mentioned above) this doesn't work with older models and a cable adaptor is needed. This only applies for android users though.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Thunderous One wrote: ↑Sat Nov 03, 2018 9:29 amHiChris1981 wrote: ↑Thu Jun 15, 2017 9:55 am Rugby, Warwickshire... don't mind coding for free if people want to come to me!
Hi Mate,Thunderous One wrote: ↑Sat Nov 03, 2018 9:29 amHiChris1981 wrote: ↑Thu Jun 15, 2017 9:55 am Rugby, Warwickshire... don't mind coding for free if people want to come to me!
There's not massive amounts of things you can code, it all depends on what options your car has in the first place, i'm sure others will update with any features i miss out... my coupe was a relatively basic spec!
Headlight washers (if fitted) - turn on/off, change functionality. I turned mine off to save on water!
Boot operation - change how the remote operates the boot, i set mine to one push rather than holding it for 2 secs.
Set up DRLs - only really worth it on Xenon headlights, mine didn't have them but set up on a friends Z4.
Power fold mirrors (if fitted) - set them up to fold when you lock the car.
Beeps and indicator flashing when locking/unlocking
Window operation - allows movement when door is opened or key removed to continue
Turn off bulb checks - useful if you install LED bulbs
Probably a few other bits and pieces and the fault reading/clearing was always pretty useful
E86 Coupe 3.0si Sport - Montego Blue, Pearl Grey with Piano Black dash
BC BR series Coilovers, powerflex bushes, 15mm spacers, Custom SS exhaust, CDV delete
- road warrior
still confused.. are we talking about the 2006 facelift ? so a 2006 needs a cable as well ?
this seems impenetrable .........
so what do i need for a 2006 pre facelift 2.0 ??
i see a small white dongle a big black dongle, and i see a cable with the old connector ..
- kis
Are you apple or android?road warrior wrote: ↑Tue Nov 06, 2018 12:10 am still confused.. are we talking about the 2006 facelift ? so a 2006 needs a cable as well ?
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- road warrior
I am android and would like to use it with my tablet and phone
- LittleZ4
Mines a 2004 pre facelift. Im using android and the Bluetooth adapters. I would of thought that a facelift model would be the same, no need for a cable surely??
3.0i Maldives blue, Coilovers, Bola B1's, Buckley06 Gear knob, Handbrake & Indicator badges, Backbox delete, CDV delete, cupra r splitter, RAM air filter, Bigger Brakes, M3 ARB, SMF.
I got the adapter but it wouldn't work so had to buy a cable.
- IAmOrion
If you bought GEN2 adapter (£45) then you also need this http://amzn.eu/d/0GYM1Hp additional adapter £11 to make it work with older cars such as <2004 E85
NO LONGER OWN A Z4 SO NOT AS ACTIVE HERE ANYMORE (IF AT ALL).
I STILL OFFER FREE CARLY CODING & EWS KEY/TRANSPONDER CODING AT MY HOME
IN CAMBRIDGE CB22
Facebook: https://www.facebook.com/groups/Z4DIYCustomMods/
IN CAMBRIDGE CB22
- IAmOrion
You don't need the cable. IF you want to play it safe, get the GEN2 Bluetooth Adapter (for Android)road warrior wrote: ↑Tue Nov 06, 2018 12:10 am still confused.. are we talking about the 2006 facelift ? so a 2006 needs a cable as well ?
http://amzn.eu/d/3Z8hZqc
AND Get this additional piece:
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
