Monkey mans power adder
- Machine monkey
Hi guys
Nope I am on holiday recharging the batteries. Been a long slog and thought going with work and a family. But looking forward to being home and getting it all wrapped up and sent away for the ECU on the 4th of June.
Monkey
Monkey
- Machine monkey
I have also got a tow car sorted. So I can rebuild it all in its final state! New injectors and the MAF deleted. So close to being done now. Just need to figure out what boost pressure they will map the car to! They said low boost? But I have a 1 bar spring in my waste gate!
Ideally you need to get the boost down to 5 or 6 psi to start with
- Machine monkey
Agreed new spring ordered. Hopefully depending on how things are looking when mapping? We will be going for 7-8 psi at least. Lots of m54b30 have run at half a bar and made the power I am after safely and using the ms43 BMW ecu.
See how you get on, always easier to turn boost up rather than down!
- Beedub
id shoot for 8-9lbs.... thats what i run and your motor is much more commonly boosted in stock form than the s54.
- Machine monkey
SCS are mapping the car and making it safe. They only want to map to about half a bar! We will see what they do and what numbers I get.
Next round of work. Oil pump, harmonic damper, engine mounts, Head bolts and gasket. Then it will go to Steve Saddler and be mapped at a bar of boost and it should be hitting high numbers then. But that’s probably a year or more away. I just want it back and to drive it for now. And tidy it up and sort out all the little things. Like some audio and the paint!! And wheels.
- Machine monkey
So this happened yesterday
After much begging and making promises to friends and family. I had my buddy Chris and the car for the day and after 8 hours driving £120 in diesel and snacks my car was dropped off and is at SCS.
Watch this space for updates.
After about 12 hours working on the car Saturday. We got it loaded where going to drive through the night. But the trailer lights where not working. I only had the x3 until 12.00 Sunday! And my buddy Chris wasn’t around.
- ph001
Big day today!
- Beedub
MM if it help you im happy to wrap the car for a very reasonable rate for a club member..... saves paint costs for another 5-7 years, we could something realy cool, about to wrap my ST in satin roaring thunder!!
- Machine monkey
Thanks that’s very kind and a nice offer.
But I have the spray booth I like the colour and if I damage anything ever I can just re paint new panels myself. One of the great things about the z4 all the panels bolt on and off. Which is very handy on a track/drift car!!
- Machine monkey
SCS want the car for 2 weeks. They need to make a loom adapter to convert the BMW harness to the pin outs on their ECU. And then check everything works as it should. Then it will go on the rolling road for its tune.
Matthew Payne at SCS thinks it might be done sooner. But it’s going to be a long 2 weeks!!!
- Machine monkey
SH1T i might have just orderd some wide over fenders for the rear!!
- Smartbear
You sure you’re not building a replica of that zed the forum helped fund? That had Carlos Fandango arches if I rememberMachine monkey wrote: ↑Wed Jun 06, 2018 8:18 am SH1T i might have just orderd some wide over fenders for the rear!!
https://youtu.be/nqqZ28m8uCo
e85 3.0si sold
