You have been busy.....a good use of your furlough timeBeefy wrote: Mon Oct 26, 2020 12:43 am Hi new to the forum, had my Z project just over a month and since I’m on furlough I’ve been making use of my time... last week I fitted new rear springs, shocks, and top mounts, relocated and repaired the roof motor, fitted poly arb bushes, and done the oil and filters. Got new front springs and top mounts to go on this week just need shocks to arrive.
- Alpina 98
I'm going to bed early on New Years Eve
Not wishing to toast the New Tier in.
Finally sorted my Drivers door switch. (Adjuster for mirrors not working) Managed to purchase a used switch for £30 and change the trim covers over. You'd never know. All working again.
2004 Black Sapphire 3.0L SE. Red leather. Back box delete. Clutch valve delete. Roof motor relocated. 18" M star spoke style 193. Machine Monkey exhaust tips. Gap Tec. ZHP Gear knob. Clear side repeaters. Zun Sport lower grille.
- Alpina 98
Great result for little outlay. I guess it's a small price to pay for owning a 15yr + carblunderthumbs wrote: Thu Oct 29, 2020 5:44 pm Finally sorted my Drivers door switch. (Adjuster for mirrors not working) Managed to purchase a used switch for £30 and change the trim covers over. You'd never know. All working again.![]()
Got it back from the garage after they had it for 2+ weeks and for 3 weeks before that it was laid up in my dad's workshop whilst I did some work on it. Totally forgot how to drive it after getting out of my old Saab 93 which I'd been using for the 5 weeks. Glad to have her back, new spings and brake lines fitted; dare I say the brake finally feel have decent!
- Phil40
Where did you get them ? They are so cleaned...
E89 2011 Sdrive 23i manual Sapphire Black - France (sorry for my english level not perfect)
- AlphaEchoAlpha
Nearly Polybush time!
- PXL_20201031_201047461.PORTRAIT.jpg (84.32 KiB) Viewed 1102 times
'07 Z4C - Gone to a new forum home
'56 S2000 - Gone.
'07 E92 M3 - Probably in a petrol station.
'56 S2000 - Gone.
- Benderloch
Bought one of those cheap glue pull kits of the infamous auction site. Sat and watched a few tutorials on that other infamous place and then thought I would have a go at the 2 small dings in the Zed. One was there when I bought it and the other was done by a prat with a suspension bush flying out the bench vice
So, glued and pulled a few goes on the boot lid 'bush' dent and brought it up flush , so just have a little scratch to touch in and polish out.The rear wing pulled a lot easier and after 4 or 5 goes is now not noticeable. For £30 for the bits I bought,was far cheaper than a dent man coming out to fix and happy with the results. Yes, there is a risk it could go very wrong , but taking my time seems to have worked fine.
E86 In sapphire black
Good effort.
- ARCS
Showed it some love
- 20201106_114254.jpg (103.4 KiB) Viewed 1111 times
2009 E89 23i Alpine white.
2008 cayman 2.7 Arctic silver.
2003 E85 3.0 titan silver - sold
Fixed a broken drivers side window regulator with a repair kit. Fiddly job.
Fitting the cable isn't the tricky bit; carefully cutting away the vapour barrier and generally working in the tight space within the door is fiddly. At least it's sorted
Also swapped onto winter tyres. Looks like the set I bought second hand are a little big. Getting a smaller tyre fitted to the fronts on Monday so I don't rub a hole in the arch liner!
2006 Z4 2.0i Ruby Black
Fitted the i6 DISA kit. The intake was clean as a whistle but the pin was hanging out when I removed the DISA
that’s at 62k and 16yrs
Very quick and easy and one less thing to worry about.
2004 E85 3.0i Roadster
2018 Seat Leon FR 180
Calipers cleaned and painted a "graphite" shade. Pad retaining clip might look better silver?
- Alpina 98
Replaced yellow capped registration screw cover. A small job that has needed doing for a little while.
- 20201107_221713.jpg (51.09 KiB) Viewed 952 times
- Phil40
So cleaned, perfect coloradam_sjg wrote: Sat Nov 07, 2020 8:37 pm Calipers cleaned and painted a "graphite" shade. Pad retaining clip might look better silver?
Do you have used a "special paint kit" ? Or just a classic spray ?
