Don't tell your wife about reducing tyre pressures on her side will make things more comfy!damok666 wrote: ↑Wed Nov 13, 2019 6:29 pm Fitted the passenger side e46 seat. The drivers side is at the upholsterers. The S2000 seats don’t have up and down movement. They’re a perfect height for me but too low for the wife and the e46 seats seem a lot more comfy.
- Alpina 98
I'm going to bed early on New Years Eve
Not wishing to toast the New Tier in.
- Smartbear
Swapped over to my winter 17’s with Michelin cross climates, gave the hubs a clean & repaint at the same time to keep them looking fresh
e85 3.0si sold
Alpina 98 wrote: ↑Wed Nov 13, 2019 7:13 pmDon't tell your wife about reducing tyre pressures on her side will make things more comfy!damok666 wrote: ↑Wed Nov 13, 2019 6:29 pm Fitted the passenger side e46 seat. The drivers side is at the upholsterers. The S2000 seats don’t have up and down movement. They’re a perfect height for me but too low for the wife and the e46 seats seem a lot more comfy.
- MACK
Thanks RocketRocket wrote: ↑Tue Nov 12, 2019 5:51 pmIt was the X8R kit. I know many people have had good results but even with the screw slackened back a turn or two the valve sometimes slightly stuck instead of turning freely. The performance was just not quite as good as it should be. Mainly in lower revs when putting your foot down. It was not a tremendous difference but just took the edge off the acceleration. The bmw new part sorted it out. I am sure the repair kits are fine as long as you can nip up the screw and still have a freely moving valve. I have read of others having the same issue when fitting the kit. I have also read of many people having no issue.MACK wrote: ↑Mon Nov 11, 2019 7:52 amHi.Rocket wrote: ↑Fri Nov 08, 2019 5:02 pm I fitted a DISA valve repair kit a few days ago but was unhappy that I could not get the valve to swing freely, even with backing of the screw a great deal. I ran the car and it seemed not quite as it should be. So I bought a new unit from BMW and fitted it today. I went for a 15 mile drive with the roof down at 7.5 C. It goes great now
Can I just ask which brand of kit did you use? I had a similar problem with an i6automotive kit when I fitted it years ago. When you say the car ran it was not quite as it should be can you elobarate on the this and difference the proper bmw part made. Thanks
Silver 05 3.0i SE
White E89 20i M Sport
Quick wash and spray wax
Then fitted solar charger to keep battery topped up
E89 2.0 i S Drive M Sport
TT MK1 Roadster
RR Evoque
Now gone E85 2.0 SE
TT MK1 Roadster
RR Evoque
Now gone E85 2.0 SE
- Phoenixboy
Washed, hoovered, tyre pressures done.
E89 s drive 30i manual/gone
space grey
Carbon interior trim
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
Gone, E85 Ruby Black.
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
1) Finally got my carly adaptor and coded out the annoying beep it makes locking and unlocking
2) Coded a few other things and cleared the stored engine codes - made sure none came back
3) Attempted to drive to the shops only to find an inch of stanley knife blade in my rear o/s
4) Local mech plugged the tyre and it seems to be holding up fine; car is off the road for at least a week so I'll see if it holds up
5) Took each wheel off, flushed the arches and gave each wheel a good clean. Winter tyres and wheels go on next week so I'll be bagging up my 107s until the spring.
On a side note, I had to use my z for the 40-mile each way commute this week in very icy conditions; lowest temp I saw was Wednesday at -7c when I left home. Car never put a foot wrong; even on icy and slushy roads it was planted, although I was obviously taking care. But it never once slid or under steered. Not bad for a semi-automatic with fat summer tyres on the rear!
Replaced the driver’s side wing mirror glass which fell out this week. Quite a common thing so I’ve read.
Bit of a bugger to get it off even after turning the release notch and ended up ripping the old one to pieces but new one is in!
Can’t say I was happy to spend so much money on a piece of glass though!!
- Tinker15
Had cruise control fitted. Many thanks to AnubisZed who did a great job and in no time at all. Tried it out on the drive back home and all is good. Very chuffed!
Winter wheels/tyres fitted then off to Dorset from Shropshire to see my aged Mother who at 98 has just gone into a wonderful home to be cared for and pampered a bit. Got back today and looked at my consumption...... motorway at a steady 70 (ish!) set on the cruise. For a 3.0 litre petrol engine, that is amazing!
- IMG_1326.jpg (285.79 KiB) Viewed 796 times
Ex E86 Z4 3.0si coupé facelift blue now Z'less
Porsche 997 C2S black-gone-, Mazda Eunos 1.8 yellow-gone-, Audi S4 Avant v6 Quattro 3.0 supercharged red-gone. Abarth 500 red. Abarth 124 Spider GT black. Porsche Cayenne red.
The 3.0 Z4 are pretty good on fuel on motorway journeys, Ive seen the trip computer indicate 41+mpg if you drop your speed to 55-60mphJl-c wrote: ↑Sat Nov 16, 2019 9:46 pm Winter wheels/tyres fitted then off to Dorset from Shropshire to see my aged Mother who at 98 has just gone into a wonderful home to be cared for and pampered a bit. Got back today and looked at my consumption...... motorway at a steady 70 (ish!) set on the cruise. For a 3.0 litre petrol engine, that is amazing!
- LittleZ4
43 is the best I've done......felt like driving miss daisy though!
3.0i Maldives blue, Coilovers, Bola B1's, Buckley06 Gear knob, Handbrake & Indicator badges, Backbox delete, CDV delete, cupra r splitter, RAM air filter, Bigger Brakes, M3 ARB, SMF.
My E89 achieved 40.3 MPG on trip from London to Malaga Spain doing around 70 to 80 MPH which included being stuck in almost standstill traffic in Paris for 2 hours! I believe the figure would have been higher probably around 43 to 45 MPG had it not been for the traffic in Paris. Truly remarkable economy for 6 cylinder 3 litre. To put it into a perspective my F20 118d doesn't achieve much more then 50 MPG on a long run doing similar speeds and that's a 4 cylinder diesel!
- scootr
I'm a lead foot.
I blame it on the Remus
E89 3.0L 6 MT gone
Michelin P4s
Bilstein struts & shocks
Luxon tower brace
Michelin P4s
Luxon tower brace
- enzed4
Ordered CSF stepped FMIC. Chargepipe next, then will look at an MHD tune.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
