- craigbeal
I’ve ordered a ak90+ for £22
- IAmOrion
Definitely not local, but I'm in Cambridge CB22 and can program key for you should you even find yourself nearby. I even have a spare diamond blanks (inc transponder and remote) for £10
DLV can also code and cut keys - another great forum user who'll be happy to help
NO LONGER OWN A Z4 SO NOT AS ACTIVE HERE ANYMORE (IF AT ALL).
I STILL OFFER FREE CARLY CODING & EWS KEY/TRANSPONDER CODING AT MY HOME
IN CAMBRIDGE CB22
Facebook: https://www.facebook.com/groups/Z4DIYCustomMods/
IN CAMBRIDGE CB22
This afternoon was spent replacing bonnet badge (what a pita even going through grills!).
Then I removed the GM5 unit to send of to company via ebay, hopefully to fix the drivers door not unlocking via remote.
Lastly since I bought this 2003 3.0 last year and had read a lot on here about the DISA failing, I thought I should take a peek even though there was no noticeable noise. Well it is certainly in need of repair, part of it looks melted. The pin was in situ but easily pulled out, the plate freely moves too, so have gone with the aluminium repair fix via X8R.
Looking forward to getting the GM5 and disa repair kit back so I can hopefully tick those ones off. Bowser134 relocated my roof motor last week, excellent job. He found the oil reservoir on the motor was very low and topped it up which resulted in a much smoother open and close on the roof.
It really helps me having this forum. I'm always using search as way to find things out, so a big thank you to everyone that has in the past written how to's and answered others questions.
- 1419C7E5-9C7D-4819-B74F-16EBC24454A3.jpeg (326.66 KiB) Viewed 933 times
2003 E85 3.0i | Titan Silver | Anthracite 107's | Stubby | Relocated Roof Motor | Disa Kit
- blackabbot
I know when I saw you and Colin had put yours on, thought I'd follow suit now the weather has turned a bit
2008, E85 2.0i sport, Titan Silver, Hardtop, ZHP Gear Knob, Chrome Exhaust Tip , Hydro Graphic Carbon Interior, DLV roof motor relocation and CDV delete and a Whippy
- blackabbot
Cracking job, must get round to doing mine, did you have to remove the airbagcraigbeal wrote: ↑Tue Oct 16, 2018 12:16 pm Removed the “si” rubberised wheel parts and sanded down using 600 by hand ready for spray today.
Used matt black spray from Halfords. Will fit once dry and post results
- Big Andra
Let me know how you get on with this as I'll need to do the same
2003 E85 3.0i titanium silver
Bilstein B4's & Eibach pro's
Poly bushes
Cruise control
Cup holders
Gaptech
Stubby
Poly bushes
Cruise control
Cup holders
Gaptech
Stubby
- craigbeal
I just released it via the rear catches but could remove all the bits with the airbag still connected so not much dramablackabbot wrote: ↑Tue Oct 16, 2018 6:51 pmCracking job, must get round to doing mine, did you have to remove the airbagcraigbeal wrote: ↑Tue Oct 16, 2018 12:16 pm Removed the “si” rubberised wheel parts and sanded down using 600 by hand ready for spray today.
- craigbeal
Thanks mate, will see how I get on with the unit from China first, fingers crossed it programsIAmOrion wrote: ↑Tue Oct 16, 2018 6:20 pmDefinitely not local, but I'm in Cambridge CB22 and can program key for you should you even find yourself nearby. I even have a spare diamond blanks (inc transponder and remote) for £10
- IAmOrion
But the AK90+ is great, does the job well. Done about 20 now with it, from memory I only had 1 transponder chip not work properly, put that down to an iffy chip and not the unit itself.
Edit: Just seen your earlier post. The AK90+ is perfect
Well worth the investment in my opinion
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
- craigbeal
Where abouts on the z4 is the EWS locates on a RHD 2006 Z4?IAmOrion wrote: ↑Wed Oct 17, 2018 4:08 pmThe AK90+ ?? If so that's what both me and DLV have (unless DLV now has a better way of doing it, I don't remember)
Will do
An all day detail and winter protection on my E86 and son did his m140
- 4F146FB8-850F-43F3-B20B-4201237FCEB7.jpeg (313.21 KiB) Viewed 780 times
- IAmOrion
See my old comment here to someone else who had EWS q's before
You can ignore have the chat, you'll see where it is from the pics.
it's kind of above the footwell speaker
viewtopic.php?p=1556126#p1556126
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
- montymog
ordered a tin of harleys to see if its better than black hole
e85 3.0si monaco metallic extended oregon cream leather.m seats all electric with heating and extensions.m multifunction s/wheel reverse sensors.light maple wood trim m suspension ect.ect. running on eagle f1 assy 3s
- Big Andra
Fitted Reinhold module
Poly bushes
Cruise control
Cup holders
Gaptech
Stubby
Poly bushes
Cruise control
Cup holders
Gaptech
Stubby
